2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Help! M5 Exhaust On Mod 550i Diffuser
      03-03-2014, 09:02 PM   #1
Catchmeifyoucanf90
Drives: f90 white m5
I want to get m5 exhaust muffler on my 2011 550. put I did a mod diffuser, so I don't know if the m5 stock mufflers will fit nicely on my new diffuser.
      03-03-2014, 09:46 PM   #2
HDEddie1
HDEddie1's Avatar
120
Drives: X5 40i, X3M40i, Audi SQ5
If your pic shows the OEM Msport mufflers in their original location, then its an easy yes, they will fit since they use the same hangers that the stock M sport muffler uses. Some minor tweaking of the quad tips are sure to be done, to your taste, but even then its no big deal since they're slip on and can be adjusted with a tap of a rubber mallet.
Now if you're thinking after market tips, 3 1/2 or even 4", then that's another challenge.
      03-04-2014, 03:01 PM   #3
Catchmeifyoucanf90
no no, I just want the sound of the m5 muffler on the 550i but yea they are stock mufflers on it now and just aftermarket diffuser. but aren't the m5 mufflers a little bit more in?
      03-04-2014, 03:27 PM   #4
LACSTER
Drives: Hybrid
Yes they are but when you go to install your M5 muffler the shop with align it for you to fit your diffuser.
If you plan on using the complete piping then you'll have some issues but it can be modified to fit.
      03-04-2014, 05:01 PM   #5
HDEddie1
HDEddie1's Avatar
120
Visually, they appear more inward and that was my assumption. Could be just an illusion with the factory M5 facia unique styling but as I and many other have found out, the M5 and M6 muffler mounts right up and will exit the standard MSport diffuser. Maybe we're just lucky and you might encounter a few nits but, having been under the car myself during the install, I can't see anything that a good muffler guy can fix with a simple tweak.
      03-04-2014, 05:12 PM   #6
Catchmeifyoucanf90
Thanks, just have to find an m5 muffler now :/
      03-04-2014, 06:10 PM   #7
scott135i
scott135i's Avatar
Drives: 2020 X5 M50i
Posted Up in a new thread about the exhaust meister.
Tags
diffuser, exhaust, f10
