03-03-2020, 07:07 AM | #1 |
Rep 72
Ticking noise
Hello,
I get a whine and ticking noise coming from under the car, it not happened in the morning but after warmed up, The noise starts to appear. The noise is the same as the below video link Does anyone know what is the issue. Thanks |
03-07-2020, 05:58 AM | #2 |
Rep 72
03-16-2020, 04:52 AM | #3 |
Rep 482
What are the shops saying? That sound is coming from your tranny even though your not shifting? That may be the exhaust downpipe possibly... take it to a shop for a diagnostic.
03-16-2020, 10:43 AM | #4 |
Rep 518
Not good. How long have you had that car? My buddy had a similar sound on his salvaged M5 he picked up. Turned out to be a damaged rod. Use a stethoscope to pin point the ticking sound.
BPM Tuned, Advanced Fuel Dynamics, Paddoq Valved Exhaust, Paddoq Magnetic Paddles, EDC dampers, Dinan Springs, H&R Sway. DCT all day long.
https://www.youtube.com/channel/UCFu...fWjCtOz49FDMlg |
03-16-2020, 01:25 PM | #5 |
Rep 68
Drives: 2011 535ix M-sport
Could be several things. First, would be to order a new filter/pan and correct 8hp transmission fluid. Then drop the pan to inspect.
Upon first noise from the video, it could simply be the magnet is loose in the pan, the internal pan is cracked if you drove over something that hit it, or a loose mechatronic with a backed out bolt. There are numerous other reasons, but not knowing the history of maintenance, your driving history, or how the transmission shifts, it cannot be diagnosed with just that video. Dropping the filter/pan is the first thing to do to inspect. Lastly, check the rubber mounts for the engine and transmission. The filter/pan and trans fluid at the very least will ensure proper fluid level and good maintenance.
'11 535ix M-Sport - FMIC, CP, BM3 engine & trans, CQuartz Finest Ceramic, Poly tension bushings, Dynamic, Active Roll, Flappy paddles, HUD, Premium(s), Cold, Convenience, 5-cameras, 4-zones, Driver's Assist, Auto high, Hex trim
'92 850i, '08 XC90 3.2 Past: '93 525i w/ S38B36 M5 engine/trans swap, '99 540i/6sp Sport, etc. |
03-16-2020, 10:47 PM | #6 |
Rep 716
Sounds like a rod knock to me...
Bmwdoubles_194.00 |
03-20-2020, 06:47 AM | #7 | |
Rep 72
Its not happened in the morning only but after warmed up the noise starts to appear, so maybe from filter/pan? i never change it before and the millage now 200,000 KM Thanks |
03-20-2020, 06:51 AM | #8 | |
Rep 72
the sound start after the car after warmed up even not shifting and there is any error or fault message. Thanks |
03-20-2020, 06:53 AM | #9 |
Rep 72
03-20-2020, 01:49 PM | #10 | |
Rep 518
The previous owner had poorly tuned the car. Probably why it was salvaged.
03-22-2020, 10:33 AM | #11 |
Rep 12
Have the same sound of my BMW F10, 528i, 2011. Already driven 13000 miles like this. Have changed the gearbox pan and oil recently, but it did not helped. Still the sounds comes on once the engine gets warmed a bit, and disappears once fully warmed up. If you will find the problem, please reply to this post!
Thanks! |
03-25-2020, 01:28 PM | #12 |
Rep 12
Put your gear paddle to manual, switch to second or third gear and this sound will disappear. Just apply the brake before switching to the second gear
It means you need to see gearbox specialist. I am going to leave my car tomorrow for this problem. Will update you with repair process. |
mrmarie16.00 StradaRedlands4958.00 |
03-31-2020, 05:59 PM | #13 | |
Rep 72
Please let me know if you get any update. Thank you |
02-19-2021, 02:11 PM | #14 |
Rep 1
Rattle noise near torque converter
You may be missing these sound insulation caps, P/N 24 14 7 603 258 and P/N 24 14 7 567 139. They plug holes in the bell housing between the engine and the transmission.
BIG_KID 2011 28i N52 with ZF 8 speed these part solved his problem |
11-01-2021, 01:24 AM | #15 | |
Rep 1
04-03-2022, 12:05 AM | #16 | |
Rep 9
04-03-2022, 12:06 AM | #17 |
Rep 9
04-03-2022, 12:08 AM | #18 |
Rep 9
Ever get it fixed? I have the same exact issue as you.
