2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum F10 550i Avant Garde M310
      05-30-2015, 01:40 PM   #1
BMW UDM
Drives: 550i 2011 DS2
Mounted Avant Garde M310s on 550 and unfortunately the combination of incorrect offsets and aggressive Michelin Pilot Super Sport tires have made this setup incompatible. Tire/Fender rub. Front: 8.5"W w/ 255/35/20 and Rear: 10"W w/ 285/30/20. Offsets are different and unknown. Maybe they can be machined ?
      05-30-2015, 04:28 PM   #2
zzzbullseye
BMW Addict
zzzbullseye's Avatar
Drives: 2011 550i (F10)
That sux that you have fitment issues. I have the same wheels (see post here), with only slightly narrower tires front and back. I'm really surprised the slight bump in tire width is causing you issues. Here are the specs for my setup:
245/35 front with a 20x8.5 wheel - offset ET30, 275/30 rear with a 20x10 wheel - offset ET38.
'11 Black Sapphire F10 550i l ZSP l Avant Garde 20" M310
      05-30-2015, 04:31 PM   #3
zzzbullseye
BMW Addict
Looking closer at your pix, it appears that your rig has a drop?
      05-30-2015, 05:50 PM   #4
BMW UDM
Thanks. It is lowered on ACS springs. Offsets should be 30mm front and 38mm back, however I'm not convinced of this yet. Did you notice how the left rear tire protrudes out further than right rear ? Was also told the Michelin Pilot Super Sports have an extreme square geometry.
      05-30-2015, 05:54 PM   #5
BMW UDM
Your car looks good without a drop. I actually used the offsets from this thread when shopping for wheels. I purchased a set of silver AG M310 as well and installed them this afternoon. Will post pics.
      05-30-2015, 06:03 PM   #6
BMW UDM
550i with Silver Avant Garde
This is what AG M310s with 30mm front and 38mm rear offsets should look like with the ACS springs. I'm not sure what the offsets are on those black wheels.
      05-30-2015, 06:17 PM   #7
zzzbullseye
BMW Addict
Weird...the stance should be the same side-to-side unless there's a difference in manufacturing between the wheels. I haven't owned Pilot Super Sports before, so no experience there.
Your car looks good without a drop...
Thanks.
      05-30-2015, 06:31 PM   #8
BMW UDM
Silver AG M310s From Behind
Here we go. Silver AG M310s with 30mm front and 38mm rear offsets and ACS lowering springs from behind.
