2010 2011 BMW 5 Series Forum F10 Driver side door won't unlock |
05-27-2015, 10:39 AM | #1 |
Rep 35
Okay so I got in the car this morning to go to the gym and the door opened just fine, the car has comfort access so I usually just pull the door handle and it opens.
I was leaving the gym to go to work this morning and the driver side door would not open. The lock pin would not come up, I tried the normal comfort access pulling, keyfob unlock and even jumped in from the passenger side and tried pulling the handle twice, none of these methods would open the door. The only thing I got to open the driver door was using the physical key! Has this happened to anyone? Any suggestions? What could cause this? PS - The car is no longer under warranty |
05-27-2015, 11:19 AM | #3 |
Rep 510
I believe it's called the lock actuator.
http://www.trademotion.com/parts/201...&siteid=214697 BMW Genuine Factory Part Part Number: 51217229461 LOCK ACTUATOR 5 Series; w/o Auto Soft Close; Left Includes Door Lock. Fits 2011 BMW 535i xDrive Base MSRP $221.49 Save $44.30 Online Price $177.19 |
05-27-2015, 11:46 AM | #4 | |
Rep 14,522
Also...any stereo/alarm shop can put these in if u don't want to be raped by dealership labor. |
05-27-2015, 01:24 PM | #8 |
Rep 510
Part Number: 51217185689 LOCK ACTUATOR 5 Series; w/Auto Soft Close; Left Includes Door Lock. Fits 2011 BMW 535i xDrive Base MSRP $442.97 Save $88.59 Online Price $354.38 i guess it is much more lol |
05-27-2015, 01:30 PM | #9 |
Rep 510
This is probably not one of those things that doesn't need a manual. It didn't look complicated when I had the door opened to change my speakers and tweeters.
First, I would make sure it's that part that's broken. Stick a volt meter on it and test it. But to give you a ballpark of how much it cost to fix. I had it fixed on my Infinity M35X a few years ago. Both my front doors' actuators needed replacement. It cost me about 2 hours of labor. Total came out a little over $400 for parts and labor. |
05-27-2015, 01:51 PM | #10 |
Rep 35
05-27-2015, 02:02 PM | #11 |
Rep 2,196
I believe mine is going bad as well. My drivers lock pops up very slowly. I just haven't had time to bring my car in though.
Bake
05-27-2015, 02:08 PM | #12 | |
Rep 510
The good news is that the actuator doesn't seem to throw codes |
05-27-2015, 08:28 PM | #13 |
Rep 35
So I was driving home and stopped to get gas, the gas door actuator wouldn't open, I had to use the emergency gas door release from the trunk to get the door open.
It's too much of a coincidence for both things to go bad, I now suspect it has something to do with the fuses. |
05-28-2015, 05:04 AM | #14 |
Rep 139
Very unlikely to be your actuator unless your car sees very adverse weather conditions or the battery has been drained a lot. Have you checked the key fob power? Definitely check the fuses.
Replace batteries in both key fobs and you may need to sync the door and key fobs again. Check car battery with voltmeter |
05-28-2015, 08:44 AM | #16 | |
Rep 510
It doesn't sound like a fuse problem since it would affect more than just the driver's door actuator. I don't know exactly how the gas door work but I think it has to do with the driver's door actuator. My gas door don't open sometimes unless I unlock the driver's door. So the driver's door lock system being broken could mess with the gas door. |
05-28-2015, 09:00 AM | #19 |
Rep 35
Wow.... So I tried playing with the lock and unlock, I noticed the doors aren't actually locking. The lock pin is staying up for all of the other doors except the driver.
05-28-2015, 09:05 AM | #21 |
Rep 510
You need to try resetting your ECU. If that doesn't work, you may need to replace it.
My previous '98 528 did the same thing after 5 years. It only happens during high humidity and rainy days... and eventually everyday. Then it started messing with other more important things like traction control. I'm guessing the seal is broken in your ECU/TCU modules like what happened in mine. |
05-28-2015, 09:40 AM | #22 |
Rep 35
Autozone wouldn't test it. The guy was so scared to touch anything. Advanced tested it but didn't take off the connector. He just attached it to the small screw (I'm not sure if that's good enough of a connection) but it only produced 556 CCA, the battery is rated at 800.
What's even weird is that the front door did open when I shut off the car and pulled the handle twice. I just can't repeat it. Definitely sounds like the battery now. |
