05-23-2013, 08:22 AM | #1 |
Rep 26
Jack Adaptor
I've searched this forum and others but can't find a definitive answer to the jacking thing. I see the need for an adaptor in order to prevent damage to the plastic housing on the jacking points, but I can't determine if the lift is actually made at point 'A' or point 'B'.
Point 'A' makes the most sense as that doesn't place any vertical pressure on the housing. In this case it seems the circular base is simply a means of locating the adaptor on the jack and the plastic housing acts as nothing more than a lateral locator to prevent sideways slip. I'm guessing there should be an air gap between point 'B' and the plastic housing otherwise it defeats the purpose of the adaptor. I'd really appreciate some clarification! Thanks. |
05-23-2013, 01:06 PM | #2 |
Rep 340
the rectangular block you have labeled as "A" goes inside the jack housings.
I just use a hockey puck, works perfect. No problems for years so far |
05-23-2013, 02:19 PM | #3 |
Rep 351
The adapter works very well, especially this one that I have that has these little plugs on the side that holds it up in the jack point pocket. BTW, the rectangular block goes inside the plastic jack point on the chassis and the jack goes on the flat opposite side.
They cost twice as much as what you can buy others on Amazon, etc. but they are worth it IMO. http://www.reverselogic.us/shop.html...07&id=21585717 |
05-23-2013, 11:47 PM | #4 |
Rep 3,834
Click on the link below for more information. Only point "A" will touch your car, there is a bit of space between the plastic jack piece and point "B" on the adapter by design. Point "B" should not touch the plastic jack piece on your car, otherwise it will defeat the purpose of you buying the jack pad adapter if the weight of the car rests on the plastic edge.
http://f10.5post.com/forums/showthread.php?t=666311 |
05-24-2013, 02:17 AM | #5 | |
Rep 26
It seems there are a lot of people without these devices (improvised or otherwise) jacking their cars directly on the plastic housing! I'm guessing the adaptor needs to be a slightly loose fit in the housing to allow for the change in angle as the car is raised, otherwise the adaptor will exert pressure on the sides of the housing. |
05-24-2013, 02:19 AM | #6 | |
Rep 26
05-24-2013, 02:20 AM | #7 |
Rep 26
05-24-2013, 08:45 AM | #8 |
Rep 3,834
05-24-2013, 12:41 PM | #9 |
Rep 26
Price all-in with shipping is around $50 from either Burger or Reverse Logic. That's not a bad price but I can get a local machine shop to make something from aluminium or steel for less than half that.
I just wanted to be sure that the car is jacked in the centre of the housing and not on the housing itself. It sort of makes sense for the part which bears on the jack to have a slight curvature to allow for angle change when lifting the car one-sided. |
05-24-2013, 03:18 PM | #10 | |
Rep 15,858
The plastic blocks will take the weight on the edges, with a block between the trolley jack and jacking point, but not the perfect way to jack the car. HighlandPete |
05-25-2013, 10:23 AM | #11 | |
Rep 26
05-27-2013, 05:03 AM | #12 | |
Rep 3,016
05-28-2013, 02:00 AM | #13 | |
Rep 26
http://www.ebay.co.uk/itm/BMW-New-Mi...item232b77ebbf Looks like it should do the job. All I need now is a new trolley jack ... |
