2010 2011 BMW 5 Series Forum F10 TPM warning when temp drops |
10-16-2015, 08:34 AM | #23 |
Rep 891
I think you need to have the updated nav system (NBT) to show the actual tire pressures. The older CIC version just gives colors.
10-16-2015, 08:56 AM | #24 |
Rep 243
10-16-2015, 01:51 PM | #25 |
Rep 5,366
10-16-2015, 02:14 PM | #26 |
Rep 45
I have the CIC, & the temps & pressures done from coding.You need the latest software update from the dealer & maybe a later build date if you're MY 2011.
10-16-2015, 02:51 PM | #27 |
Rep 257
As I understand it, you will get a warning when it drops below 3psi from where you have it set. Temp change = correct pressure, reset tpms. Get a digital gauge to check it on the reg during seasonal changes. Aftermarket wheels disregard factory recommendation as they are for factory stated set up. I run 20s at 39 psi front and rear that have a max of 50. Got mine coded to show pressure and temp but same as ezair's no info. TPMS may not be able to monitor that info on the 2011s or 12ss??? 1st world problems.
10-16-2015, 04:01 PM | #28 |
Rep 243
10-16-2015, 08:25 PM | #29 | |
Rep 45
