2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum BMW 550i vs BMW m3 e92 SC vs JB4 335i n54
      10-26-2015, 04:20 PM   #1
Bossman535
Drives: Alpine white
What's up guys.
Got a bms stage 1 tune on my 550i. My buddy has a supercharged e92 m3 MT, I believe making 475-500 crank hp. I recall he said he runs high 12s on the 1/4 mile.
My other friend has a RWD n54 335i AT running jb4 stage 2 I believe he's somewhere about 350-360 to the wheels.
What can I expect running against them both ?
      10-26-2015, 04:24 PM   #2
Simple5
Drives: F90 M5 and E84 X1 Xdrive35i
I seen a youtube video of a 550i stock running a e92 335i with jb4 on map 2 on stock turbos pretty much even from a go and after 100mph the 550i starts to pull.
You may lose to the SC M3 though by how much? I don't know... both v8 and the e92 m3 is 3704lbs opposed to the 4300lb 550i...
If you have an XI you would have the advantage off the line for sure.
      10-29-2015, 01:32 PM   #3
493263
493263's Avatar
71
Drives: 2011 550i xDrive
Your 550 puts out about 380-390whp stock. With BMS, you'll be up to about 440whp.
Your biggest advantage against the M3 is if you have xDrive for a better launch and better torque curve. The M3's torque is only about 260 lb/ft at the wheels. Your 550 with BMS will have over 300 lb/ft at 2k rpm while the M3 will be at about 210-220 lb/ft.
Despite the weight disadvantage, I think you will tie or beat the M3 at launch to the 1/8 mile. The M3 will catch up by the 1/4 and might even edge you. It will be a close race is what I'm saying.
The 335 will probably lose by .3 - .5 secs
