2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum N55 Oil Pan Gasket labor times - RWD
      04-25-2020, 01:44 PM   #1
OnlyGerman
OnlyGerman's Avatar
Drives: F15, F13, F10, E60
Hello. What is the average labor times for a oil pan gasket for a non x drive N55 535? I am seeing many varying times (hours).
And how complicated is this job, many components to move?
Thank you
      04-25-2020, 06:31 PM   #2
Trainwreck914
Trainwreck914's Avatar
Drives: BMW F10 F15 E39 E90 E53
I know for awd they go around 10 hrs on the book. It's not a great difference in time to remove the front axles and differential. I can't see it being more than 1-2 hrs added to the bill. So you figure 8-9 total on rwd. I've done it myself on a e53 awd. It's a job. But if I had to do it again it would probably take me half the time. I did it on my back. With a lift it's cake.
      04-26-2020, 10:37 PM   #3
Encendido3
Encendido3's Avatar
Drives: 2016 535i M Sport
I did mine on a 2011 535 after it ate a belt. It's a bitch to do while laying on your back if you are a bigger than average person. There just isn't much space to move around. Only issue I ran into was I couldn't figure out how to get the subframe out without removing a million other things. I ended up dropping the pan as much as I could and putting the be gasket on while under the car. I spent the better part of 2 days doing it with help from a more "nimble" friend.
      04-26-2020, 11:07 PM   #4
Trainwreck914
What about getting the belt pieces out?
      04-27-2020, 10:27 AM   #5
OnlyGerman
OnlyGerman's Avatar
Thanks for the replies. Extended warranty is only offering a certain allowance for it. They said they are using all data. They are right at 7.5. I will be on the hook for the difference, not complaining as there is always usually some gap with these warranties. Just glad it was approved.
      04-27-2020, 07:44 PM   #6
Trainwreck914
Glad to hear.
      04-27-2020, 09:02 PM   #7
mness
Drives: 2013 535iM
Mine was done a few months ago, covered by Route 66. Holy shit just checked the bill and it was 11.5 hours at $225/hr (SF area). Glad I didn't pay!
2013 535i M-Sport: Carbon Black with Oyster/Black Dakota, SAT, Driver Assistance Pkg, Premium Pkg, Multi-Contour Heated Seats, Navigation, H/K stereo. Michelin Pilot Sport 4S non-runflats, M5 grille, Painted reflectors from IND.
      04-28-2020, 10:38 PM   #8
mediocrechris
Drives: 2016 535i xDrive
That is insane.
      05-01-2020, 01:11 PM   #9
OnlyGerman
OnlyGerman's Avatar
Are new oil pan bolts recommended when doing this?
      05-01-2020, 04:37 PM   #10
Surly73
Drives: '11 535xi 8AT KWv3 MPE MHD xHP
Every single other job on the F series calls for new bolts, I can't see the oil pan gasket being any different.
Just looked it up so I'm not just being a smart alec:
https://www.newtis.info/tisv2/a/en/f...-sump/Am4JN6AB
"replace screws" all over the place in the instructions and on the torque sheet.
      05-01-2020, 08:38 PM   #11
OnlyGerman
OnlyGerman's Avatar
Wow I did not know that. Warranty should reimburse me for it since it is officially required. I am sure they will put up a fight though ...
      05-01-2020, 09:06 PM   #12
OnlyGerman
OnlyGerman's Avatar
Did they cover the bolts, or did they just keep the original?
      05-04-2020, 10:11 AM   #13
OnlyGerman
OnlyGerman's Avatar
Update: warranty said no coverage for bolts as it is hardware. Suckers. Oh well!
      05-06-2020, 12:02 PM   #14
mness
Drives: 2013 535iM
Ha, no, I had to pay about $50 for "Set of aluminum screws". Still, compared to what was covered, I was thankful to pay it.
