2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Hood won't open
      05-11-2020, 08:06 AM   #1
CanadianTSi
CanadianTSi's Avatar
Drives: 2014 535 xDrive Diesel
Hood won't open
I installed a set of H&R Lowering Springs in my 2014 535 Xdrive. After I was done I shut the hood and then went to pop it and now only the passenger side latch releases. Any idea what I did? or how I can get the hood open??
Thanks
      05-11-2020, 08:08 AM   #2
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Not sure what would cause your hood from opening from a spring install? I'm not sure what other way to open the hood. Good luck with that
      05-11-2020, 08:27 AM   #3
CanadianTSi
Same, but that was the only thing I touched on the car and the latch was working fine at the start on the install.
      05-11-2020, 11:08 AM   #4
beegeezy
beegeezy's Avatar
70
Drives: 2013 535i M-Sport
Try lightly pushing down on the hood where that latch is while someone pulls the release.
      05-13-2020, 08:28 AM   #5
CanadianTSi
Just thought I would add how I managed to get it open in case anyone is searching in the future.
After removing the wheel liner on the driver side, you can just barely see the hood release cables running between the coolant reservoir and the body of the car. I managed to hook onto them with some thick wire and pull quite hard (a coat hanger was to flimsy and would bend) which got the latch to activate.
There is a plastic collar on the hood latch cable where it hooks into the latch mechanism. I must have knocked this collar out of the slot it sits in when I was moving around the coolant reservoir to access the suspension bolts for the spring install. I popped the collar back into the slot and all is well.
      05-13-2020, 08:53 AM   #6
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
I was gonna say the route you took is correct
