2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Clunking when braking slotted rotors.
      03-21-2024, 08:57 AM   #1
Supahone
Supahone's Avatar
Drives: 11 550I, 07 335I,
When braking my f10 550xi I can hear a clunking sound as if the calipers are clamping onto the rotors and I feel it over the steering wheel. Ive bled the brakes several times. Anyone had this happen after swapping over to slotted and drilled rotors?
      03-21-2024, 12:07 PM   #2
Unspec
Unspec's Avatar
1300
Drives: 2015 BMW 535xi
Thrust arm bushings going bad?
2015 BMW 535xi
ISTA VM Setup/Tutorial
      04-14-2024, 04:11 PM   #3
poverty.f10
DIY Mechanic
poverty.f10's Avatar
Drives: 2012 BMW 535i xDrive
Check your thrust arm bushings. Try to move the arm side to side where the bushing connects and see if it flex’s a lot.
You can live in a car but you can’t race a house.
