2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Angel eyes : differences in angel eyes brightness ?
      04-14-2011, 04:20 AM   #1
karmakal
Belgium
63
Drives: G30 530D (iX50 on order)
I'm the owner of a 520D F10 with visibility package (xenon lights).
August 2010 build.
I'm crossing more and more F10 these days with daylights looking much brighter than mines.
Can it vary from one car to another ?
Is it possible BMW improved the angel eyes brightness on the latest builds ?
      04-14-2011, 05:01 AM   #2
mlai
mlai's Avatar
Hong Kong
170
Drives: 650GC/E93M3/Lexus LS600HL
Could be a case of "The grass is greener on the other side"?
F06 650i Gran Coupe Ruby Black/Dakota Cinamon- 2012-10-12 Adaptive Drive/IAS/Surround View/Adaptive LED/Comfort Seats/BMW 356 Liquid Black/Michelin PSS 245/35R20-285/30R20
E93 M3 Cabriolet Satin Pearl White/CR - 2012/03/12 Bilstein PSS10/ Michelin PSS 245/35R19-265/35R19 Brembo GT
2011 F10 550i M Sport - Retired
      04-15-2011, 01:03 AM   #3
AlBoston
Drives: 2019 740i xdrive & 2018 640GT
The Angel eyes do have 2 brightness levels. If they are used as DRLs they are in the "bright mode" . Headlights on or parking lights are in the "dim" mode... Actually unverfied with parking lights but 'm pretty sure it is dimmer.
      04-15-2011, 03:25 AM   #4
bike99
Drives: F15 25 xDrive
I did check it - it has 2 brighness levels. So depending how you switch your lights - they may look different.
BTW - how do you know that someone's lights are brighter than yours when you are driving your car?
      04-15-2011, 03:42 AM   #5
karmakal
Belgium
63
@bike99
Thank you for the 2 brightness levels info. Didn't know that.
I checked brightness on my car in daylight mode (is it the same as DRL?) and with engine on. So I suppose it's the same as when driving even if I'm not in the car unless the eyes dim when the car is not in movement.
Btw, yesterday I crossed a 3 series with LED angel eyes as bright as Audi's LED. The bimmer was stopped at a traffic light. Maybe a mod ?
      04-15-2011, 05:06 AM   #6
northernmonkey
northernmonkey's Avatar
Drives: F11 530d MSpt
personally i wouldn't want them too bright otherwise they look a bit tacky....like a cheap after market mod. i'm happy with the level mine are at now.
      04-15-2011, 05:07 AM   #7
karmakal
Belgium
63
Ok I found the explanation. Daylight option was off in the settings.
Now its on and it looks indeed much much brighter.
Pic 1 : daylight setting off
Pic 2 : daylight setting on
      04-15-2011, 05:21 AM   #8
cliveywolves
Drives: 330e M Sport Plus Edition 2020
Yep i tend to agree when the are set onto the very bright setting , they do stand out a lot more, but do look a bit tacky like the cheap after market kits you find on other makes etc...
      04-15-2011, 06:32 AM   #9
Needsdecaf
Needsdecaf's Avatar
6599
Drives: 2024 G80 Comp xDrive
So if you turn off the DRL option, the halos still stay on, but dimmer? Interesting.....will have to investigate! I thought it just turned them off altogether.
      04-15-2011, 11:38 AM   #10
blackberrycubed
Drives: 535i Xdrive
so what did you find out?
      04-15-2011, 04:58 PM   #11
Needsdecaf
Needsdecaf's Avatar
6599
They simply went off.
      04-17-2011, 12:39 PM   #12
karmakal
Belgium
63
In order to have the angel eyes dimmed, switch to parking lights with DRL setting off.
You will have the same effect as in picture one above.
      04-17-2011, 07:09 PM   #13
Needsdecaf
Needsdecaf's Avatar
6599
Tried that. They went out the one time I did it. Tried again, and it worked. Interesting to know.
      04-18-2011, 01:44 AM   #14
AlBoston
You didn't find any explanation. I posted this same explanation for you earlier.
      04-18-2011, 02:56 AM   #15
karmakal
Belgium
63
Yes AIBoston, thank you for helping out
      09-05-2012, 04:29 AM   #16
copycat1103
Drives: f11 520d
Hi,
I drive a f11 without visibility pack for one year.
There are angel eyes but the brightness is less than I see on passing F10's with xenon.
Is there a way to make them brighter and switch of the normal lights? It would be good to have that together with automatic light switch enabled.
      10-16-2015, 05:55 AM   #17
bmw5seriesman
Drives: BMW 5 Series
I have F10 bmw 5 series 2011 reg with a normal headlights and was wondering if there is a way to enable Angel Eyes day time running lights with bright light on it? I have seen the cable and software on ebay to do some coding but not quiet sure if that would enable what i want?
      10-16-2015, 09:52 AM   #18
splitsensetam
Drives: 2011 535i xdrive
My car was coded to have the halos on full brightness when headlight are on. you might be seeing this on the streets.
      10-17-2015, 10:57 PM   #19
Atlantis M3tallic
Atlantis M3tallic's Avatar
57
Drives: 2017 M3 ZCP
I did the same, my angel eyes stay bright even when the HIDs are on.
Current: 2017 F80 M3 - ZCP
Previous: F10 550i M Sport - Alpine White - Vossen CV4 Graphite / H&R Sport springs / Active Autowerke Down pipes & Exhaust / BMS Stage 1 / M-Performance Front Splitter /DTM CF Diffuser
      10-17-2015, 11:28 PM   #20
Same here.....
      10-18-2015, 06:19 AM   #21
mikejohn
Drives: X5
I have a 2014 F11 M Sport if that makes any difference, the angle eye's are bright when in automatic switch on mode i.e. light switch all the way left, but dim when in manual mode i.e. one click right from centre or two clicks from centre, personally don't find it a problem as I leave the light switch in automatic mode all the time.
Mike
