2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums UK Anyone successfully coded F10 in the UK?
      10-16-2017, 12:05 PM   #529
JLR1969
Drives: Kubota GR1600
Originally Posted by gspannu View Post
Could you try these settings and let us know if the overall quality improves...
B&O Expanded: Off
Fader +2
Treble +4
Bass 0 (or +1)
100Hz -2
200Hz -1
500Hz 0
1KHz +2
2KHz -3
5KHz +4
10KHz +6
It sounder crisper
Not sure the treble need to be so high though
Maybe also better in expanded mode
10KHz better if not as high
All personal taste I suppose
gspannu199.50
      10-17-2017, 02:40 PM   #530
MrPogle
MrPogle's Avatar
Drives: F10 550i M-Sport LCI
Originally Posted by xenon View Post
With bi-xenon headlamps on full beam you wouldn't even notice the fogs being switched on. If I had my way, fogs would be illegal anyway - hateful things.
Simple solution. Law for vehicles to be electronically limited to 50mph when the fog-lights are on. That would make them turn them off when they weren't needed.
      10-18-2017, 10:13 AM   #531
gspannu
Drives: F10 535, F82 M4
Originally Posted by JLR1969 View Post
It sounder crisper
Thanks. That confirms my thoughts as well. I think if you leave 10kHz at +6, but set the treble to 0 or +1, it will sound better (all relative !)
Also, listen to expanded mode and normal mode multiple times; the expanded mode sounds better when the car is still, but in a moving car the normal mode sounds more natural.
I also tried another trick. Asked my better half to switch between normal/ expanded and I did not know which was which. All I noted was whether I liked the sound or not - and did this multiple times randomly. Eventually settled on normal with the settings above, but Treble at +2.
JLR19691882.00
      01-29-2018, 02:00 AM   #532
AbdulA
Drives: BMW F10
Hi,
I'm a complete novice on coding. Does anyone how to disable the pedestrian protection sensor?
I believe on other forums you have to delete 8TF and remove fgs connector.
Does anyone know how to do it?
Thanks
      02-14-2018, 11:32 AM   #533
wufy
Drives: f11 520d
Might be not a good idea to delet it though. Why?
      02-20-2018, 04:48 AM   #534
Mescapon
Drives: 2014 F10
Hi Abdulla , I am curious as to why you would want to disable this function?
      02-20-2018, 04:51 AM   #535
Mescapon
Drives: 2014 F10
Hi Guys, anyone in London or Swindon area who can help with 2014 F10 coding
      02-20-2018, 04:53 AM   #536
Mescapon
Drives: 2014 F10
My car came loaded and I am trying to enable the following
- Bootlid opening via the driver boot release button
- Video in Motion
- Enable Enhanced Bluetooth (allow my car stream Bluetooth music through the speakers)
      02-20-2018, 05:41 PM   #537
mrashton
Drives: 2017 G32 6GT; 2014 F45 218i
- Video in Motion
Is your car specced with auto boot opener? If so the driver's kick panel button is there to open the boot. If you want to close it from there too then you need coding.
I'm in Orpington Kent and can help with the coding.
      02-20-2018, 06:34 PM   #538
Mescapon
Drives: 2014 F10
Thanks a lot, I already downloaded E-sys and the other instructions from shawnsheridan but yet to download PSDzdata as the files are too large and I am out of space on my laptop
I am in Bromley quite close to you, and can pop over to you Saturday afternoon if you're free?
yes my car has the power boot option as I can currently open and close the boot using the key fob, button in the boot or using my leg behind the boot.
      02-21-2018, 06:17 AM   #539
gspannu
See attached Bootlid
- Video in Motion
See attached VIM
I'll have to dig these up from my notes...
      02-21-2018, 08:18 AM   #540
Mescapon
Drives: 2014 F10
Attachment 1772501
- Video in Motion
See attached VIM
Attachment 1772502
Thanks, will VIM also enable videos such as mp4 and other formats to be played via usb? If not, do u know how I can have this enabled as well?
      02-21-2018, 12:21 PM   #541
mrashton
VIM won't enable MP4 playback but we can have a look at that when we start the coding. I'm afraid I won't be around on Saturday (although I usually am). Sunday or the following weekend will be ok for me. Send me a PM with your VIN number and I'll send you my phone number so we can arrange this.
      02-21-2018, 04:19 PM   #542
Mescapon
Drives: 2014 F10
Thanks, sent u a PM
      02-21-2018, 04:22 PM   #543
Mescapon
Drives: 2014 F10
I did some googling and came across this thread on how to enable USB in Idrive and different video formats;
http://www.bimmerfest.com/forums/sho...d.php?t=668902
For activating Video playing from USB.
HU_NBT 3003 API_USB_VIDEO --> both
this enables the menu selection of "movies" in i-Drive for the USB-Device
if you want to play DivX/Xvid contents as well (or Video-cD at that) the following Settings are also necessary.
HU_NBT 3000 ENT_CODEC_XVID --> aktiv
HU_NBT 3000 ENT_CODEC_XVCD --> aktiv
And it definitly digests almost everything you throw at it.
mpg, avi, mkv, divx .....
even at HD Resolution
Anyone with VIM done this?
      02-21-2018, 04:28 PM   #544
Mescapon
Drives: 2014 F10
Also found this link for Enhanced Bluetooth Coding but not sure if it is applicable to F10
http://f30.bimmerpost.com/forums/sho....php?t=1414327
      04-19-2018, 06:25 AM   #545
NickCW
Drives: BMW 530d
Does anyone have a link to the correct cable/software for coding?
Bit of reading seems to imply you can pick them up quite cheap, i'd love to set my mirror delay on close to 0.0s to save holding down the key button..
Thanks!
      05-08-2018, 02:55 PM   #546
Del1407
Drives: F16 X6 2015 30d M Sport
I replied to your post yesterday… do not know where it disappeared. I guess I had posted a link to another forum site (maybe against forum rules - my apologies)
Anyway, my offer is 100% genuine. I am happy to code your car. I did code another forum member's (@ap) car last week.
I live in Basingstoke and work in Winchester; I'm sure we can work out something convenient - keep me posted when your car arrives.
Hi Gspannu I’m new to the forum and was hoping you could help code my car to enable SLI 8TH? Car comes with KAFAS2 camera with LDW and Driving Assistant as factory options. I know there will also be the FSC code to obtain but any help would be much appreciated!
Thanks
      01-01-2019, 11:56 AM   #547
giumusbmw
Drives: BMW F11
Originally Posted by Amdb9 View Post
OK so please explain yourself? Im new so not sure if I've said something I not meant to. Dvd in motion is perfect for my kids. Im good enough to not watch Toy Story or Disney Princesses on the screen
      01-01-2019, 12:32 PM   #548
giumusbmw
Drives: BMW F11
Download it here.
FANTASTIC
      08-30-2019, 07:26 AM   #549
hems77
Drives: 2019 G30 520i M Sport
Hi All
I'm a returning BMW driver after just purchasing a 2015 530d M Sport a couple of months back. I switched to a C Class W205 for a couple of years after having an E90 previously - had to get back in a BM! The Merc was nice but just not the same and I found the quality very poor. Always wanted a 5 - after looking at options for a G30 the prices were working out too much for me. In the end settled on a AUC F10 - decent spec and low miles so went for it.
Anyway been looking at coding options and know of the vgate dongle and bimmercode app and looking to add some things to my car, mainly -
- fold mirrors on lock (have to hold on fob at the mo)
- digital speedo
- M Sport welcome screen
- anything else I can get...
Instead of buying the kit for one off use, I wondered whether anyone on here could offer to code any bits for me? I'm in the Coventry/North Warwickshire area...
Hope someone can help?
Cheers
      08-30-2019, 08:10 AM   #550
gspannu
Originally Posted by hems77 View Post
Hi All
I'm a returning BMW driver after just purchasing a 2015 530d M Sport a couple of months back. I switched to a C Class W205 for a couple of years after having an E90 previously - had to get back in a BM! The Merc was nice but just not the same and I found the quality very poor. Always wanted a 5 - after looking at options for a G10 the prices were working out too much for me. In the end settled on a AUC F10 - decent spec and low miles so went for it.
- digital speedo
Cheers
I am based in Basingstoke (weekends)/ Southampton (weekdays) and can code this for you. Let me know you ever come around to this side.
All done FREE ! No costs...
