2010 2011 BMW 5 Series Forum F10 Please help I'm new to this |
11-02-2020, 07:34 AM | #1 |
Rep 6
Hello Gentlemen,
Want to install different wheels on my 5 series. Front: 8.5x20 ET38 Rear: 10x20 ET51 Will these wheels fit my car? And what size tires should I put on? |
11-02-2020, 01:13 PM | #2 |
Rep 2,591
I'm fairly certain those rears will not fit and would hit the shock. You'd 100% need spacers if you wanted it to work.
2015 BMW 535xi
Eadames0.00 |
11-02-2020, 04:07 PM | #3 |
Rep 915
If you have them in possession try a test fit. Other then that remmib the wheel guy may chime in. Send him a direct message.
Instgram @burninja
Eadames0.00 |
11-02-2020, 05:53 PM | #4 |
Rep 6
I've put them on just trying to figure out tire sizes..how do I message him?
11-02-2020, 05:54 PM | #5 |
Rep 6
I've put them on just trying to figure out tire sizes..you think it'll still rub?
11-02-2020, 11:05 PM | #6 | |
Rep 2,591
Need a side picture, not a straight on picture.
2015 BMW 535xi
11-03-2020, 04:37 AM | #7 |
Rep 915
If you search forum type in remmib it will come up with his posts. Then click his name and send private message.
Instgram @burninja
11-03-2020, 07:01 AM | #8 |
Rep 6
Is this a good picture?
11-03-2020, 08:46 AM | #9 |
Rep 2,591
Might be easier if you tape a piece of string with a weight on the end (plum bob) to the fender. It's hard to tell where everything lies in relation to each other.
Again, is it touching the shock?
2015 BMW 535xi
11-03-2020, 09:21 AM | #10 |
Rep 29,202
Lots of room in the rear wheel arches of the f10, but et51 is a high offset so you might like to put on spacers for a nicer/more aggressive looking fitment.
11-03-2020, 10:25 AM | #11 |
Rep 6
11-03-2020, 10:57 AM | #12 | |
Rep 29,202
Eadames0.00 |
11-03-2020, 11:26 AM | #13 |
Rep 1,356
I recommend a 15-20mm spacer for the rear. Best to figure it out when you have it measured with the tires mounted.
Tires Aggressive (may rub a little over hard bumps) Front 255/35/20 Rear 285/30/20 Safe (no rubbing) 245/35/20 275/30/20 |
