2010 2011 BMW 5 Series Forum F10 275/30R20 on 11 inch wheel? Is Kumho usable? |
03-10-2019, 01:59 PM | #1 |
Rep 10
does anyone have a picture of 275/30R20 or 275/35R20 on a 11 inch wheel? maybe also with kumho tires?
Purchased my new 11" wheels and looking for a minimalist stretch kind of wheel with tyre. Gonna run with 20x10" 245/35R20 front and 20x11 275/30 (or 35) back. Looking for referens pictures. not gonna slam the car, only lowering springs, that's why im hesitating. |
03-10-2019, 11:49 PM | #2 |
Rep 14,521
here's my 21x11 with 295's with a slight stretch. so with 275's it'll really be stretched in my opinion
this is with my coilovers setup high to give you a better look at the sidewall
03-12-2019, 03:08 PM | #3 |
Rep 29,203
If the fitment allows, why not go with 285/30/20?
03-16-2019, 02:39 PM | #4 |
Rep 10
What offset u got with those 11" ? tried my 11" with et 35 looks good but felt like it stick out a bit to much, saw an with et 28 if im not mistaken and it runs flush with fender??
03-17-2019, 06:06 AM | #5 | |
Rep 29,203
03-17-2019, 08:54 AM | #6 |
Rep 14,521
like remmib said yes these are ET 38mm which to me is flush and no SPACERS! 275's to me would be stretched!
03-18-2019, 09:11 AM | #8 |
Rep 14,521
I think so. doesn't matter the wheel size but it's still the same width 11" so 275 will have a really stretched look. if you look at my 295's and that's 20mm more and it still has a slight stretch from the pictures I posted. from most post listed guys running with an 11" width are trying to either get 295, 305 and even 315's to fit tho a 315 you're better off with a 12" wide wheel
03-18-2019, 08:18 PM | #9 | |
Rep 1,397
03-19-2019, 11:24 AM | #10 |
Rep 14,521
yes 255/30 r21 on a 9.5" wheel. need to run a spacer but now sure how much?
03-19-2019, 05:33 PM | #11 |
Rep 1,397
lsturbointeg9169.50 |
03-19-2019, 05:37 PM | #12 |
Rep 14,521
5mm That's probably about right. Gonna raise the car to get at least a 1/2" gap when it warms up a bit. Still in the mid 20's
03-26-2019, 08:55 AM | #13 | |
Rep 12
03-27-2019, 08:09 AM | #14 |
Rep 385
Drives: 16 X3 28d/18 540d xdrive
Not to detract from the car's great looks, but how do you manage Ohio roads without damaging those tires and/or wheels? I drive in NE Ohio regularly (in fact Cleveland on Monday) and do concede that most roads are better than those in PA, but there are areas under construction such as I 271 around Cleveland that never seem to be completed. It appears that even speed bumps might be a challenge.
03-27-2019, 07:53 PM | #15 | |
Rep 14,521
03-28-2019, 09:13 PM | #16 | |
Rep 12
Lukaas541.50 |
04-01-2019, 01:38 PM | #17 | |
Rep 8
Drives: 2014 BMW 535i //M Sport
I run 285/30/20 on a 10.5 wheel in the back, and that's already stretched to my eyes. You're going the opposite directions on tire and wheel size (smaller, and wider). If they are correct offset and not poking out, I'd hit a 295/30/20 and call it a day. Don't think I have enough posts to share pics yet, so they may be invisible. :/ |
04-02-2019, 08:14 PM | #18 |
Rep 55
I'm running 20x10.5 +42 on the rear with 285/30/20 and it's a slight stretch so a 20x11 on a 275 will be a stretch stretch. I would do a 295 or a 305 on a 20x11.
04-24-2019, 01:08 PM | #19 | ||
Rep 9
Front fit is good ? You have spacer ? Thanks 🤗
Lukas
04-24-2019, 11:30 PM | #20 | |||
Rep 12
Lukaas541.50 |
Tags |
275/35r20, f10, tyre, wheels |
