2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding Current Software Version
      03-10-2017, 12:22 PM   #23
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Originally Posted by berndh View Post
Ok thanks for the clarification. But I still don't get it totally. Mine says NBT_Dxxxx. I thought the D is the firmware version of the NBT. How can I tell that my NBT firmware is the latest?
Yes, D is the firmware version; therefore, you do not have the latest.
Updating BT Media & Communication, alone, will not change NBT_Dxxxx.
      03-11-2017, 02:10 AM   #24
berndh
Drives: BMW F11 525d
Is there any change log available for the different firmwares? What functionality am I missing.
      03-11-2017, 12:02 PM   #25
Almaretto
Almaretto's Avatar
2374
There are for the small BT Media & Communication *.bin's. There are not for the computer ECU firmware updates.
      03-11-2017, 12:24 PM   #26
berndh
Thanks. I did find the idrive software and updated to latest. Now I will see if I can upgrade the nbt firmware.
      03-12-2017, 05:13 PM   #27
Originally Posted by Almaretto View Post
You are welcome.
I have not checked in the New Year; but, last website version I saw was UPD05074.bin for NBT, which corresponds to MN-002.255.071, TN-002.255.070.
So, if your existing BT Media & Communication is greater (eg, MN/TN-003.002.001), then update will fail.
Finally drove the car so got to check. Both MN and Phone (doesn't say TN) is 003.013.01...
      03-12-2017, 05:54 PM   #28
Almaretto
Almaretto's Avatar
2374
That is the latest version.
So, attempting to install UPD05074.bin (MN-002.255.071, TN-002.255.070) would fail.
      03-12-2017, 07:21 PM   #29
Almaretto
Almaretto's Avatar
2374
You can also check compatibility.
  • All Apple products I select, it says no email support.
  • For Android, it says no for Pixel XL; but, yes for Galaxy S7. There is the following note:
    • "It is recommended to use e-mail app from manufacturer for optimal transmission of e-mails. Currently transmission of e-mails is not available with Gmail app.
    • In order to be able to display e-mails in the vehicle, the mobile phone must be set up correctly for e-mails."
      03-12-2017, 11:06 PM   #30
THANK YOU VERY MUCH!!!!!!! That explains it!
Makes me wonder why BMW's update site says that update is applicable to my VIN...
      03-12-2017, 11:36 PM   #31
Almaretto
Almaretto's Avatar
2374
Each time your vehicle has service, a report is sent to the motherland. But, those servers do not necessarily sink back to ConnectedDrive portal. As such, it can lead to confusion.
Though, that is why it is nice that release notes are posted, so you can see exactly which version the update contains.
      03-13-2017, 12:04 AM   #32
Each time your vehicle has service, a report is sent to the motherland. But, those servers do not necessarily sync back to ConnectedDrive portal. As such, it can lead to confusion.
THANKS for the explanation. Having worked for the Gummint my whole career I understand the lack of communication between entities.
How would one interpret the release date as it applies to the each car? Does the type of service matter? I bought the car used...
      03-13-2017, 12:12 AM   #33
Almaretto
Almaretto's Avatar
2374
Which release date?
Each service does not result in vehicle programming. But, each service involves scan with ISTA+ which communicates back to BMW as well as online systems can lookup previous service history.
      03-13-2017, 02:05 PM   #34
Which release date?
The update release date...
Ahhhh...... That explains the process well!!
      03-13-2017, 02:39 PM   #35
Almaretto
Almaretto's Avatar
2374
  • For the UPD05074.bin (~90mb)
    • © 2016 Bayerische Motoren Werke Aktiengesellschaft
      Munich, Germany
      Not to be reproduced, wholly or in part, without written permission from BMW AG, Munich.
      English VIII/16, Readme_UPD05074_en-gb.pdf
  • For Flash Programming (~2GB, for HU_NBT; 80GB All Firmware)
    • SIB (Service Bulletins) detail new releases & availability dates. EX:
      • Subject: Workshop Technology: ISTA/P 3.61.1, ISTA 4.04.20 and HDD-Update 2.3.6253.18078
      • Message: The following software packages will be released Monday March 13, 2017
        ISTA 4.04.20 - Diagnosis and programming data
        ISTA/P 3.61.1 - Programming and coding data
        Due: 3/27/2017
        Note: On 3/27/2017 we will disable all ISTA 4.03.X and older versions. ISTA 4.04.12 (released 2/24) will be the oldest supported version.
        The release notes are currently being translated and will be loaded onto TIS Technical Documentation when they are made available.
        Brands: These applications are applicable to all brands.
      03-15-2017, 10:02 AM   #36
feeling
Drives: 535D
Hi Almaretto , would have PMd but need 1 post (which is this!),
I am trying to find as much information as I can about the NBT system and you seem to know alot about it!
I have come from a 2016 M135i with NBTEvo to a 2015 535D with NBT. I have updated the media / phone via the bin update (02.225.070 / 071 / 072) and updated the maps to 2017-1 (Europe), but upon reading your posts and searching the internet, my istep(?) isn't the latest NBT_I14472A and I saw that the latest NBT from one of your posts was O I think? Is there a change log for I to O out there?
I noticed on my NBTEvo when I plugged my phone in, it would load up all the apps that were compatible with the car, Spotify and ConnectedDrive apps without me doing anything. On this I have to open the app myself for it to play anything via the cable.
Is it possible to update the NBT firmware? If so, how? I have downloaded esys / pzdata (lite) / ISTA-P (I think) but not sure where to start as there are many guides out there for coding various tweaks but not updating the firmware. I haven't coded anything yet as I am guessing it will just wipe it with a firmware update.
Would it be possible to give me a detailed guide?
Thanks,
Feeps
      03-15-2017, 05:55 PM   #37
Almaretto
Almaretto's Avatar
2374
Thanks,
Feeps
There are never change logs or release notes. And, software updates rarely, if ever, come with new features. They are more to improve the functionality of existing.
HU_NBT and HU_NBT2 (AKA EVO) are two different systems. Plus, the ladder has multiple versions.
It is possible to update the firmware. This is done with either ISTA+ with SDP & an ICOM, ISTA-P with ICOM or ENET, or E-sys with ENET or ICOM and PSdZData_FULL. The process, though, is riskier than coding and requires a PSU.
      06-11-2017, 11:50 AM   #38
speedometer
CIC system
Hello,
Sorry to be bringing up an old thread. I have an '11 f10 with CIC. I have connected drive on my car but tethering does not work with an iphone 6. It tells me to activate data services or something.
I thought maybe updating the media system would help. So i downloaded the latest software shown on the website which is UPD01008 and installed it but my bluetooth data services still dont work.... I know there are newer versions out there, however 1. I dont know where to get them from, and 2. if they would be compatible with my system. For ex. would an NBT update work on mine?
Would an update even help with my data services situation? Any thoughts are appreciated.
Thanks!
      06-12-2017, 02:52 AM   #39
Almaretto
Almaretto's Avatar
2374
Only two places to get:
  1. BMW Website
  2. Flash Programming
Software is head unit specific. You cannot load NBT on CIC.
      06-12-2017, 02:27 PM   #40
speedometer
  1. BMW Website
Thanks for your reply. I guess I am stuck with UPD01008
      07-04-2017, 10:23 AM   #41
feeling
Drives: 535D
Hi Almaretto ,
What is the latest software? I had my dealer update my istep (4 months ago) to O and also on MN/TN-003.002.001 but when I put my chassis number in the update website it returns UPD05062 (23.1 MB) as the latest.
Having a few issues with contact syncing, as in when someone calls the number appears in the idrive and not the contact name, tried deleting and unpairing but has no resolve so was wondering if there was a newer update out?
Thanks!
535D M Sport LCI - 3.0L N57D30T1 | 313PS | 630NM
      07-04-2017, 08:15 PM   #42
Almaretto
Almaretto's Avatar
2374
Hi Almaretto ,
Thanks!
Latest is MN/TN-003.013.001. You would have to check release notes for UPD05062, but UPD05074 is older than your firmware.
      07-05-2017, 02:56 AM   #43
feeling
Drives: 535D
Hi, the release notes state MN-2.255.60, TN-2.255.62 for UPD05062 which is older than what I have applied.
How do you download the latest as BMW doesn't seem to let me get the latest update via the website?
Do we know when MN/TN-003.013.001 was released?
Thanks for your replies
      07-05-2017, 01:28 PM   #44
Almaretto
Almaretto's Avatar
2374
The only way to download latest is with complete head unit firmware and flash program.
Files are encrypted and cannot easily be assembled as *.bin to install via usb.
That version was released last Fall and included in February, April, May, and June releases.
