2010 2011 BMW 5 Series Forum F10 SAT gear shifter swap on 2015 535 m sport |
06-28-2018, 11:51 AM | #1 |
Rep 38
Good afternoon all....1st time poster here. I have a 2015 f10 535 m sport (no paddle shifter) and added sport + via coding. My question is, can i plug and play the new SAT gear shifter without any additional coding? And also what part number is compatible with my old gear shifter? I read certain year have different pin connectors... i really love the look on the shifter with the leather cover..i've seen a 2016 f10 shifter at a junk yard and wanted to know if it can be swap with my 2015..thank you all in advance.
06-29-2018, 12:37 AM | #2 | |
Rep 5,366
06-29-2018, 11:40 AM | #3 |
Rep 951
I don’t believe you need to code the paddles. They should just work once a steering wheel with paddles is installed. However you do need to code the car by updating the FA to add 2TB and remove 205 option on a couple modules including the cluster. Without the added coding you won’t see the S1-S8 in your cluster when in sport mode. There are a few other thread about this so do a search and you’ll find the whole process
06-29-2018, 12:31 PM | #4 | |
Rep 5,366
06-29-2018, 06:03 PM | #5 | |
Rep 38
i'll keep you posted when i do the swap. once again, thanks for the input. |
06-29-2018, 11:29 PM | #6 | |
Rep 5,366
07-07-2018, 06:22 PM | #7 |
Rep 1,126
I currently have 2013 luxury line, have coded 2tb, but have also owned 2013 535i m sport with 2tb, brother also has 2015 X6 n55 m sport with 2tb. The factory 2tb shifting is much more sporty as in bolt riffle action, or more bang sound during shift, or aggressive hard shift which I can't duplicate just by coding. I know many say there is no difference but I certainly feel it.
07-07-2018, 07:20 PM | #8 | |
Rep 1,214
What you "feel" can be a number of things including differing adaptations, it could also be in your head but it most certainly is not factory vs. retrofit physical difference. |
07-07-2018, 08:22 PM | #9 |
Rep 1,126
07-07-2018, 08:48 PM | #10 |
Rep 1,214
My wifes F25 X3 35i (which is factory 2TB) always felt more "aggressive" up its upshifts compared to my 14 535i, and that is attributed to the AWD system, not the transmission itself.
Again direct from the horses mouth of ZF's international training team BMW's Sport Automatic Transmission is a software change only and the transmissions are completely identical. Using a factory diagnostic tool like ISTA reset the adaptations on your F10 and then go beat on it a bit. You'll find it will change its shifting behavior right off the bat to be more aggressive and rude if that is what you ask of it. |
07-08-2018, 10:45 AM | #11 | |
Rep 1,126
07-08-2018, 12:47 PM | #12 |
Rep 1,214
I understand what you're getting at, its just not something that pans out for discussion when you understand whats going on behind the scenes.
If you remove 205 and add 2TB to the vehicle order, then have ESYS carry out vehicle reprogramming it is fundamentally indifferent from the manner it is configured and encoded at the factory level. The new G30 you drove has the 8HP50 in it, which is ZF's 2nd generation 8HP unit for the inline 6 BMW's like the B58. Technologically a whole whole lot has changed, there are no linear comparisons to be drawn there. |
07-13-2018, 11:34 AM | #13 | ||
Rep 38
InHousePerformance113.50 |
06-05-2020, 07:03 PM | #14 |
Rep 3
How do you code Sport+?
Dear rahdigga165 ,
how the hell did you code sport plus? I coded everything onto my car from bimmercode, but can’t find sport +. please help. my instagram is the same as my handle on this, if it’s easier for you to reach out there -Wolf |
