2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding Is the clock spring replaceable on its own?
      06-04-2020, 11:43 PM   #1
Unspec
Unspec's Avatar
1300
Drives: 2015 BMW 535xi
Does anyone know if the clock spring is individually replaceable on the F10, or do I have to replace the entire steering switch unit? I have a feeling my clock spring is going bad, my paddle shifters seem to only shift consistently when the steering wheel is turned a certain amount. Already confirmed that everything is working as expected on the steering wheel itself.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      06-05-2020, 11:27 AM   #2
Looks like it's pretty easy (though not an F10)...
https://www.youcanic.com/vehicle/bmw...ng-replacement
https://www.newtis.info/tisv2/a/en/f...uster/AjKOKdfj
https://www.realoem.com/bmw/enUS/sho...diagId=61_2348
I didn't see a listing for a separate clock spring (BMW calls it Steering Column Switch Cluster).
Looks expensive:
https://www.ecstuning.com/Search/Sit...h/61319354048/
      06-05-2020, 12:19 PM   #3
Unspec
Unspec's Avatar
1300
Looks expensive:
Yep, the actual replacement doesn't look hard. Was hoping I can just buy the clock spring alone, but it looks like I can't, and my dealer said they're never sold separately. Seeing if I can buy a salvage SZL and just swap the clock spring and turn stalk over. Going to retrofit the HBA button while I'm at it, might as well.
2015 BMW 535xi
