2010 2011 BMW 5 Series Forum F10 Any chance to get music playing through BT audio on F10 2011? |
06-29-2020, 04:43 AM | #1 |
Rep 10
So I have F10, May 2011 production date, and all I want is to be able to play a music/podcasts from my iPhone. Or at least, play music from USB.
I am new to BMW world, so I will give all the info I have here: 1. S606A Navigation system Business - this is what I have, as I understood. 2. Prod Date 2011-05-27 I don't see any Bluetooth on iDrive. I don't have USB port under central console. There is one USB inside glovebox. I don't know if I have combox. But I can check later. So, what are my options getting musing playing in my car? Also, please tell me, what system I have here? Is it CIC, NBT? So that I know what I am dealing with? Actually any information will help me a lot since BMW has so many options. |
06-29-2020, 01:53 PM | #3 |
Rep 2,591
You definitely have CIC. NBT wasn't introduced until prod date 9/12. Your best bet is doing a NBT retrofit. Those android head units are usually garbage.
2015 BMW 535xi
06-29-2020, 02:44 PM | #4 |
Rep 26
I have a CIC 2012 550I and I am able to play audio through my bluetooth. All you have to do is connect phone via bluetooth, and when you're on your phone in the telephone menu, hit options and it should show up an option to click on audio. once this is done, go to multimedia and hit bluetooth audio.
06-29-2020, 07:42 PM | #5 | |
Rep 5,365
06-29-2020, 09:55 PM | #7 |
Rep 5,365
06-30-2020, 06:36 AM | #8 | |
Rep 10
06-30-2020, 06:39 AM | #9 |
Rep 10
06-30-2020, 06:45 AM | #10 |
Rep 10
S609A Navigation system Professional
S615A Expanded BMW Online Information S616A BMW Online S620A Voice control S639A Preparation f mobile phone cpl USACDN S693A Preparation BMW satellite radio S697A AreaCode 1 for DVD S6AAA BMW TeleServices S6ABA Control for Teleservices S6FLA USBAudio interface S6UHA Traffic Information S6VCA Control for Combox this is what I found here in this forum. So, given that I don't have S6VCA and S6FLA, there is no change that I might have combox, and play music from USB. Sad. |
06-30-2020, 06:46 AM | #11 |
Rep 10
06-30-2020, 07:22 AM | #12 | |
Rep 1,261
06-30-2020, 08:16 AM | #13 |
Rep 10
06-30-2020, 03:38 PM | #14 | |
Rep 5,365
https://www.bavlogic.com/?p=4176 https://forum.bmw5.co.uk/topic/127301-combox-f07/ https://www.bimmer-tech.net/category...ombox-retrofit https://www.bimmerretrofit.com/store...&product_id=65 http://www.bpmsport.com/combox-retrofit.html https://forum.bmw5.co.uk/topic/13391...mbox-retrofit/ |
OnlyGerman363.50 |
06-30-2020, 07:29 PM | #15 |
Rep 1,261
Strange, I thought they all had USB. Your cheapest route would be Bluetooth audio via aux jack. Obviously no control from the car, it would be limited from the device. Many of these aux to BT audio devices available now.
07-01-2020, 07:02 AM | #16 | |
Rep 10
One of them has very small battery, so after about an hour battery dies. This one is connected to AUX under the central console and since, I don't have a USB there, I need to charge it somewhre else, of course no music while it is charging. Then I bought another one, Xiomi. It is FM transmitter, connected to cigarette lighter, so it is always on. The power problem is solved, however, it picks up another public FM stations. I have a lot of noise there. |
07-01-2020, 07:22 AM | #17 |
Rep 10
by the way, what if I will buy used ComBox and try to fit it?
again, first question can ComBox fitted to my car? If yes, then will it enable Bluetooth streaming? below are list of options I have: S1CAA Selection of COP relevant vehicles S1CBA CO2 package S1CDA Brake Energy Regeneration S205A Automatic transmission S230A Extra package, EU-specific S2K1A BMW LA wheel, V Spoke 236 S2PAA Wheel bolt retainer S423A Floor mats, velours S428A Warning triangle and first aid kit S464A Ski bag S465A Through-loading system S494A Seat heating driver/passenger S4ATA Interior trim finishers black high-gloss S508A Park Distance Control (PDC) S534A Automatic air conditioning S548A Kilometer-calibrated speedometer S606A Navigation system Business S698A Area-Code 2 for DVD S853A Language version English S880A On-board vehicle literature English S8KAA Dummy-SALAPA S8SCA Telematics access request,country-spec. S8TFA Active pedestrian protection S8TLA Dummy-SALAPA S8TNA Daytime run.lights adjus.via light menu S8V1A Label S962A Deleted, licence plate support front |
07-01-2020, 07:25 PM | #18 |
Rep 951
So, you are in a uniquely bad situation with regards to BT. If you don't have Combox, you can retrofit one, but it will require running wires up to the center console and adding the USB plug next to the AUX connector. Then you also have a bunch of wires going between CIC and the Combox (mic connection) and then of course the antenna etc that you're probably missing... BTW< my car has exact same build date but its a USA car so it has Combox.
I recently did a retrofit to NBT. SO the problem with doing any of these retrofits is you either go with a complete solution from someone like bimmerretrofit or another, but they charge quite a big for their custom emulators not to mention the cost of the new headunit/display/controller. You can get lucky and find great deals for all of these..but if you don't buy their emulator, you'll have to either retrofit the newer ICM in your care(under the center console) OR buy another emulator which essentially connects your PDC/Camera/HDC buttons to the rest of the car, since right now, those buttons are connected to your idrive controller (don't ask why BMW did this...its like they wanted to save a few cents since all the drive controller is doing is converting those button events to CAN messages). So bottom line is OEM solution wise, you are SOL unless you do the full retrofit to NBT or NBT EVO. IF you decide to go that route, I'd recommend then go all out for the NBT EVO since that's almost the latest and greatest. The NBT is good enough for me as it is MUCH faster than CIC and it has basically all the features I would have wanted except Apple Car Play. Non OEM solutions you. right be able to find something like this video below : |
