07-07-2020, 11:08 AM | #1 |
Rep 20
6WB Cluster Donor Cars?
I'm trying to track down a 6WB cluster for my F10 M5 and was wondering which year/model should I be looking for? I can get the VIN and confirm it has the 6WB option but it would help if I knew what range of vehicles had the same dash and what year the 6WB was available on.
Also, does it matter if the donor car had HUD? My car does have HUD. Any other options matter? I will either be virginizing or having it done professionally. Thanks! |
07-07-2020, 12:12 PM | #2 | |
Rep 1,261
07-07-2020, 12:40 PM | #3 |
Rep 4
Drives: E53 4.8is , F10 550i , E92 M3
6WB production period
The answer to your question is in the list bellow the first 6WB is from 07/01/2014 , so that mean that you need to search donors from that year , you can search from the list of the models that you can see in the attached photo . You will need work to the EEPROM , and the coding will be adding 6WB to the VO, changing VO Production date to 1211, and VO Coding DKombi and HU_CIC.
The first part number is:62109363263 Multifunctional instrument display From:07/01/2014 To:03/07/2015 (ENDED) Superseded by: 62109383669(03/01/2015 — 12/09/2015), Exchangeable 62109395969(04/27/2015 — 03/08/2016), Exchangeable 62106821074(03/01/2016 — 10/14/2016), Exchangeable View post on imgur.com Best Regards |
07-07-2020, 10:04 PM | #4 | |
Rep 20
