2010 2011 BMW 5 Series Forum F10 Alignment Don't - Front Camber not in spec |
09-18-2014, 09:31 PM | #1 |
Rep 154
Hey team..
I took my 2012 528i non sport to a local shop recommended by an independent BMW shop I've used before… When I got my alignment print out everything was within specs EXCEPT for the front camber both left and right. I did a few searches and some people claim that the front camber CANNOT be adjusted like the rear. Something about needed plates. Is this true? (I was planning on returning to the shop to ask them why they did not get the front camber into spec) |
09-19-2014, 02:11 AM | #2 |
Rep 634
out of spec in what way?
I would guess the spec is something like -0.8 degrees. if you have more than that, up to -1,5 I would be happy, less than spec I would not be happy. A higher negative number will give you better cornering and less tire wear on the outside. On my M3 I was running -1,5, on my 850 I am running -1,3. Looking at the parts catalog, item #13 is for camber adjustment (the horse shoe shaped thing in the upper right corner). However I doubt it can adjust much. If your camber has a higher negative value than the spec I would not worry about it. |
09-19-2014, 03:07 AM | #3 | |
Rep 15,858
My question would be, why has it moved from specification with the original wishbone? Damage or wear in other suspension components? HighlandPete |
09-19-2014, 08:20 AM | #4 |
Rep 154
The sheet says the normal range is -0.1 to -0.9.
Both my fronts are positive. Left is 0.3 and Right is 0.1. If I understand correctly... You CANNOT adjust front camber, I must purchase the above referenced parts? |
09-19-2014, 12:05 PM | #5 |
Rep 1,597
I'm pretty sure you can adjust, I had mine tracked recently and I'm sure they adjusted it. I will try and dig out the print out from the Hunter machine to verify
09-19-2014, 05:17 PM | #7 |
Rep 634
you need to get that fixed, you really don't want positive camber.
If yo imagine these lines as your wheels seen from the front of the car, / \ this is negative camber, | | this is zero degrees camber and \ / this is positive camber. Since I am not at home I can't look at my car I cant help you out by checking myself. There is in theory a cheaper solution, you could make oval holes like on the E46 M3 on the top mount. think the M3 was able to get about -1,2 degrees camber using just those holes, but not sure I would recommend that. Think I would get the -30mm new arms. |
09-19-2014, 08:45 PM | #8 |
Rep 154
Thanks for the responses.
Is 0.3 and 0.1 enough tilt to cause problems? I looked at my tires and do not see any uneven wear BUT i do hate that the camber is not dialed in to 0.0 Also, I did add 20in rims but i thought that would not create any camber. |
09-20-2014, 01:19 AM | #9 | |
Rep 634
do you have the before and the after values? Or better, post the entire sheet. Depending on the cars weight and your driving style a positive camber will give you excess tire wear on the outer half of the tire, especially the outer edge, this is because more force is exerted to the outside of the tire when turning when the camber is off. if you start to see evidence of wear on the tirewall this is a sign your camber is not negative enough. Also the front end slip limit will be lower, meaning your car will understeer sooner with a negative camber. The camber should not be 0.0, most BMW's use a camber from -0,5 to -1.0 as OEM settings. My old E46 M3 was set to -0.8 stock, and even with that it would wear the outside of my tires during normal driving. I used the oval holes and got something like -1,2, but I eventually ended up with camber plates and running a -1,5 camber on the street, and -3 on the track. To me you have 3 options. 1. change to a new stock camber arms to correct this. 2. change to adjustable camber arms. 3. lower the car. If you plan to lower the car, this may be enough to get the camber within spec, as lowering the car will normally increase the negative camber. |
09-20-2014, 04:07 AM | #10 |
Rep 1,597
I got it done at an independent, but they have the same Hunter wheel alignment machine that BMW use. Make sure that any shop your using has this equipment. They hook up the machine and show you on a screen the tolerences on all wheels, both camber and track. They then adjust those that need adjusting and give you a final print out showing both before and after. The report is easy to interpret as the figures are highlighted in a RAG status, obviously red - considerably out, amber - slightly out and green - within tolerance
09-20-2014, 09:57 AM | #11 | |
Rep 15,858
I not sure how much movement (if any) there is with top wishbone mounting bolts. But the design appears fixed from a quick visual. HighlandPete |
09-20-2014, 10:39 AM | #14 |
Rep 1,597
And here are the results from my alignment, minus my personal details...
Current: VW Transporter Sportline, F48 X1 20i M Sport. Previous: F10 530d M Sport, W176 A200 CDI AMG Evolution, E70 X5 3.0 SD M Sport, F20 120d M Sport, E81 120d M Sport, E46 325i M Sport, E46 318ci & Many Others...
09-20-2014, 05:18 PM | #15 | |
Rep 634
My old E46 M3 is the only BMW I have seen this camber adjustment possibility on. I doubted the F10 had this. Older 3 series I have owned there was a bolt with an offset you could buy to do very small camber adjustments, I know they had this for the E30 and E36. the factory bolt was straight, but this offset bult was available. I guess the F10 does not have any adjustments, so we are back to the 3 options I mentioned above. |
03-19-2019, 08:32 AM | #16 |
Rep 364
Hi
Just had my alignment checked, front camber is out - in spec on the left, right side is +0.8 Is there any way to correct this? Car is at 125k miles, no suspension parts have been changed whatsoever apart from tie rod ends this week (hence the alignment check) |
03-19-2019, 09:41 AM | #17 | |
Rep 15,858
Or, the other option is an aftermarket wishbone from Meyle. It has an adjustable ball joint. |
03-23-2019, 02:12 AM | #18 |
Rep 1,386
The only ways I see for the front camber to change are:-
1) Some lower suspension component(s) or the front crossmember is bent, pulling the bottoms of the wheels inboard. 2) The mounts for the upper wishbones have moved outwards. In either case it would suggest some major trauma to the vehicle or a slow stretch of some component or mounting to move things. |
03-23-2019, 07:24 PM | #19 |
Rep 1,044
You could always put a drop on it which will naturally lower your camber. I’m lowered on H&R 1” drop and my camber is -0.6 and -0.5 which I’m perfectly happy with.
02-04-2020, 01:27 PM | #20 |
Rep 2
Need help for front camber angles
Please Help everyone!
I had a 2011 bmw 550i w/ M pkg, my right front camber angle is +1.1 degree, left front is -1.1 degree. Is this bad enough to replace the control arm? Thanks for your help! |
02-04-2020, 01:28 PM | #21 |
Rep 2
Please Help Noggie,
