2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum rough Idle
      04-17-2011, 11:07 AM   #1
bamboozle
Drives: 550I
rough Idle
I started noticing my car has a rough idle. It has gotten worse and today I got and engine malfunction reduce power. I am taking it to the dealer.
      04-18-2011, 01:19 PM   #2
LuvMyE92
Occasionally frequent poster
LuvMyE92's Avatar
3000
Drives: CT5V-Blackwing
Same problem on my 535. They haven't figured it out yet. Keep us posted!
Current inventory:
F22 & G05
Cadillac CT5-V Blackwing w/3 pedals
Past: E24,E28(3),E34,E36,E37,E38(2),E39(4),E46,E89,E92 (obviously),F01,F06,F10,F30,F87,G12,G30(2),G82(2)
      04-18-2011, 06:03 PM   #3
bamboozle
Drives: 550I
LuvMyE92, I will. I dropped the car off yesterday and they told me to give them until Monday or Tuesday. I did not hear back from them today.
      04-25-2011, 06:11 PM   #4
bamboozle
Drives: 550I
I got my car back today. Here is what they did and found. They found first misfire codes 140601 140008 14501. They performed a fuel composition test and fuel grade and passed. Performed a smooth running test and verified cylinder six was running slightly richer than all other cylinders. They removed all spark plugs and found six and eight fouled. Eight was also covered in fuel. They performed a monitoring of fuel rail pressure to verify for leak, also performed a compression test on all cylinders to make sure no hydrolock on engine due to fuel leak. They tested all injectors. They replaced injectors 6 and eight. They also replaced spark plugs six and eight. They recovered and recharged A/C system and bled coolant system. They calibrated injectors 6 and 8. They did road test and cold starts over night to verify no misfire, checked injectors were not leaking or faults present. I hope this fixes the issues
      04-26-2011, 10:32 AM   #5
marcielago
marcielago's Avatar
United Arab Emirates
12
Drives: SG F10 550i MSport, CB E39 M5
Hope your car is fine after all that. Please provide us with insight about your car when you get it back. (I assume you haven't received it yet)
Cheers
      04-26-2011, 04:54 PM   #6
bamboozle
Drives: 550I
marcielago, I picked the car up yesterday afternoon. It seems to be running fine, but time will tell.
      04-27-2011, 06:21 AM   #7
LuvMyE92
LuvMyE92's Avatar
3000
Good luck. I've filed a complaint with BMW customer service over my issues. Waiting to hear back from them.
Current inventory:
F22 & G05
