2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions Cornering light replacement - help needed
      09-25-2017, 12:15 PM   #23
bake
bake's Avatar
Drives: 2011 F10, 2013 E93
I just replaced my passenger side bulb yesterday. This DIY was helpful. Confirmed no screws need to be removed, but it does take some force to turn the bulb socket from the locked position. The access hole is relatively small (I have big hands) and the socket sort of digs into your fingers as you are gripping it. I found it helpful to put on a pair of work gloves and got it out. It is a 3 min job once you figure out the best way to position your hands to grab.
Bake
2011 Alpine White on Black 535i M-Sport
2013 Space Gray on Fox Red M3 Vert
      12-04-2017, 02:33 AM   #24
Stealth_Bomber
Drives: 2014 BMW 535 M Sport
What about installing these? HID H7 cornering bulbs any thought?
http://www.xenondepot.com/H7-HID-Kit...ID-p/xt-h7.htm
      12-04-2017, 01:10 PM   #25
Aaron@Autosource
Aaron@Autosource's Avatar
98
Drives: F110/F22
No point, I wouldn't bother. Ballasts require warmup time and cornering lights don't stay on long enough to let that happen.
John H.230.00
      12-04-2017, 01:32 PM   #26
Stealth_Bomber
You know that didn't dawn on me. Thanks. Wondering now which is the best and brightest I can get. Any idea?
      12-04-2017, 01:34 PM   #27
Aaron@Autosource
98
Drives: F110/F22
NP. I used an H7 led kit, about $75 and you will need to wire in some resistors. Not that the OEM cornering lights weren't bright enough, but I wanted yellow inners so that's why I gottem.
      05-29-2018, 09:20 AM   #28
kostik83
Drives: 2012 535i M-Sport
what a pain that was to twist it and put it back, but the results are worth it. I ended up using pliers to twist it to remove it. you only need to twist about 15-20 degrees. putting back is a little easier, just make sure you put it same way back.
once you remove the bulb, you will need a small flat screwdriver to get he H7 bulb out of the metal housing and replace it. put it back and twist it in place.
I used Philips Diamond Vision H7 bulbs purchased on ebay. The match angel eyes very well!
      03-07-2019, 11:28 PM   #29
John H.
John H.'s Avatar
Drives: 2014 535i XDrive
Hi Aaron. Do you still have the yellow CLs installed? If so, got any pics? I would love to see them.
      12-05-2019, 10:40 AM   #30
Pedro187
Drives: BMW M8 Competition
i can confirm
Guys and galls i can confirm the torx screws do not need to come out , i just changed my cornering bulbs , torn my hands to shreds but no removal of Torx required. Its just and odd design. Look for an alignment lug like a small metal arrow , you will be able to see that this moves approx 2 cm to basically you can twist is about 2 cm it will them come away
