2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions Replace small screen with big screen?
      07-29-2016, 09:12 AM   #1
lemos
Belgium
20
Drives: g21
Is it possible to replace the center console screen (GPS and what not) small screen with the large screen versions?
Is it DYI? What would the cost be? I've searched throughout the forums, but haven't found an answer.
Thank you!
      07-31-2016, 07:00 PM   #2
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
what car are you talking about year?
I think somebody have done this before just have to code unit to work
      08-06-2016, 12:39 PM   #3
berne
Sweden
46
Drives: BMW 135i
BMW 520d F11 2012
      06-02-2019, 09:44 AM   #4
noxious55
Drives: 2012 M Sport F10 520d
I'm looking for coding instructions for this swap, I have the small CIC screen on my 2012 F10 and I bought the 10.25" screen.
Did you get any luck with your swap?
      11-04-2019, 12:39 PM   #5
fontiablanco
Drives: Man
Hi, did you get instructions to encode the small CIC screen for 10.25 "?
I also want to do it, could you inform me?
      11-13-2019, 07:38 AM   #6
FrannieMoral2017
FrannieMoral2017's Avatar
Drives: 2010 BMW 550i GT
Was anything achieved with this? Got a CIC in my F07 want to upgrade.
      06-05-2020, 05:13 AM   #7
lukaszpx
Drives: Bmw 520d
I refresh the topic, did anyone manage to do it?
      06-05-2020, 07:39 PM   #8
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Still waiting for people to chime in. I also have the 6" CIC screen and bn I've been seeing the 10" screens for less than a $100. Want to confirm if its straight plug n play?
      06-06-2020, 02:55 PM   #9
dzz
Drives: 2015 BMW 535xi, MHD Stage 2+
2015 BMW  [0.00]
As far as I know it requires coding to at least change screen resolution since 10.25" screen has higher resolution than 6". It may require additional coding for other things.
      06-06-2020, 09:24 PM   #10
lsturbointeg
No other cables needed or components tho? I'm assuming if I just swap the screen without coding the picture will be stretched?
      06-06-2020, 10:27 PM   #11
I'm pretty sure it won't work w/out the coding. Or, if it does it may have the bars at the sides. Let me look around; I think I recall reading about the small to big screen change from some European guys.
edit:
This?
      06-07-2020, 07:48 AM   #12
lsturbointeg
edit:
This?
i'll check out the video bro. i'm not even sure i'll even get that display? sucks cuase there's not enough info out there to say what happens if you swap without coding or with? and specifically what coding needs to be done exactly. that video is also a touch screen so i don't know if the one's for less than $100 that i've seen have this capabilities?
      06-07-2020, 01:29 PM   #13
dzz
2015 BMW  [0.00]
edit:
This?
edit:
This?
Android screen is one way to get screen upgrade, some people like it some don't. It is usually cheaper than other routes to upgrade screen and get modern looking menus, apple car play and Android auto. I have seen some people running MHD on Android screen so they can get a number of gauges on the screen that MHD provides with logging module which is kind of cool.
Since 2011 F10s have CIC, you may consider NBT or NBT EVO upgrade. You may get them from used parts places or eBay
      06-07-2020, 02:05 PM   #14
lsturbointeg
do you happen to know if going the Android route if coding still needs to be done?
      06-07-2020, 06:07 PM   #15
dzz
2015 BMW  [0.00]
According to this video no coding is needed
Just a setup on an Android unit, post install. You should get Android 10 unit, that is the latest version.
This is quick feature overview
This is another style of Android head unit, different look, same features
