08-03-2013, 07:48 PM | #1 |
Rep 14
X-drive tires
Anybody running 255/35/20 and 285/30/20 tires on xdrive? If so have you had any problems with running this setup. Need to decide on some tires and looking for some help
thanks |
08-04-2013, 02:35 PM | #3 |
Rep 187
Analog is right. I was concerned about sizes when I was looking for staggered on my x-drive. With help from this forum I made the decision to pull the trigger. I'm running 245/285 with no problem. 255 might be too big for the front.
08-04-2013, 06:04 PM | #4 |
Rep 14
Still learning about tire sizes so let me know if i am looking at it incorrectly . When i plug in the diameters in 1010tires calc the OEM BMW 245/275 shows overall diameter 679.5mm/673mm(.96%) and the 255/285 shows 686.5mm/679mm(1.105%) . the difference seems pretty small.
08-06-2013, 11:42 AM | #5 | |
Rep 76
245 and 255, in both cases with 285 in back. Both setups should work. |
08-06-2013, 12:14 PM | #6 |
Rep 263
Drives: 2012 BMW (F10) 528i Xdrive
Generally these setups should work, but not on an X-Drive. If the difference in overall diameters is big, then the X-Drive system would be confused and messed up.
BMW F10: A formula to captivate the senses.
2012 528i XDrive Alpine white |
08-06-2013, 12:28 PM | #7 | |
Rep 76
Both setups are for xdrive they say. |
08-10-2013, 09:33 PM | #10 |
Rep 14
One More question - I did the 255/285 setup. Car feels rear heavy and little sluggish. Is that normal with a staggered setup? Never did staggered before so trying to understand if staggered does that to a car compared to square setup
thanks |
08-10-2013, 11:36 PM | #11 |
Rep 815
Drives: G05 X5,G20 M340,Infiniti Q50RS
Dont know about sluggish and heavy..when i hit the peddle, it moves and move fast.. i have have no issues at all with this setup..what wheels and home lbs they have?
2020 G05 MSport 40i--Phytonic Blue Metallic/Vernasca Coffee Leather/Multi Contour SeatsTrim/Executive Package/MSport Brakes/Icon Adaptive Led HeadlightsW/Laserlight/Harman Kardon/Heated Front Seats Armrests & Steering
