2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum BMW F10 2011 550i with Dual Batteries!
      10-05-2014, 06:58 AM   #1
hatemax
Drives: BMW 550i
on the process of installing BMS S2, I needed to disconnect the battery but I've found something different in my car, two batteries!
the question now is, why there is extra battery? and how to disconnect the two?
(vin: C765321)
      10-05-2014, 10:01 AM   #2
The X Men
Drives: 2013 X3 35i
where is the 2nd battery?
      10-05-2014, 10:14 AM   #3
hatemax
Drives: BMW 550i
here
      10-05-2014, 02:28 PM   #4
Bavarian Tech
Bavarian Tech's Avatar
267
Drives: 335i
2006 330i  [10.00]
Its for the active rear steer. Just disconnect the negative lead as usual for any car.
      10-05-2014, 03:49 PM   #5
hatemax
Drives: BMW 550i
My brother has 535i with active rear steering but no extra battry.
      10-05-2014, 04:24 PM   #6
aclockwrk
Drives: '15 M3 6spd
My car ('12 550i) has the same, it definitely for the active steer. As it was stated earlier, pulling the negative cable off the main battery will cut all power.
      10-05-2014, 05:15 PM   #7
Noggie
Noggie's Avatar
Norway
285
Drives: E31 850i,i3s
do you have an auxiliary heater? a Webasto or something?
I know cars with that usually have an extra smaller battery installed.
      10-05-2014, 06:12 PM   #8
hatemax
Drives: BMW 550i
Bavarian Tech and aclockwrk
thank you for the info. as I said earlier, my brother has 535 with active steering (all wheel steering) with one battery only! for sure there is other things that require additional power. The 535 has same spec to the 550 except for ARS, NV, ACC. Maybe one of them is the reason of the additional battery
one more thing, if I disconnect the battery, do I need to visit the dealer for adaptation or code clearing?
Noggie
thank you buddy, I don't have auxiliary heater. please see below car spec for reference.
Production date: 09.12.2010
S1CDA Brake Energy Regeneration
S4NBA Autom. climate control with 4-zone ctrl
S4URA Ambient interior lighting
S548A Kilometer-calibrated speedometer
S212A Equipment, brake syst. country-specific
S223A Electronic Damper Control (EDC)
S229A Dynamic Drive
S255A Sports leather steering wheel
S258A Tire with run-flat functionality
S2H9A BMW LM Rad V-Speiche 356
S2TBA Sport automatic transmission
S2VAA Adaptive Drive Chassis & suspens. setup"Adaptive Drive"
S2VHA Integral active steering
S316A automatic trunk lid mechanism
S322A Comfort access
S323A Soft-Close-Automatic doors
S3AGA Reversing camera
S3AWA Washer nozzles, unheated
S403A Glass roof, electrical
S415A Sun-blind, rear
S416A Roller sun vizor, rear lateral
S423A Floor mats, velours
S428A Warning triangle and first aid kit
S430A Interior/outside mirror with auto dip
S431A Interior mirror with automatic-dip
S441A Smoker package
S456A Comfort seat with memory
S488A Lumbar support, driver and passenger
S4CEA Fine woodgrain vers., Fineline anthrac.
S502A Headlight cleaning system
S508A Park Distance Control (PDC)
S522A Xenon Light
S524A Adaptive Headlights
S5ACA High-beam assistant
S5ADA Lane departure warning
S5AGA Lane-change warning
S5DFA Active cruise control+Stop&Go function
S5DLA Surround View
S5DPA Park Assistent
S601A TV function
S609A Navigation system Professional
S610A Head-up display
S620A Voice control
S633A Preparation, mobile phone, Business
S677A HiFi System Professional DSP
S696A DVD changer
S698A Area-Code 2 for DVD
S6FHA Rear Professional entertainment center
S6FLA USB/Audio interface
S6UKA Night Vision with human recognition
S6VCA Control for Combox
S775A Headlining anthracite
L822A GULF VERSION
S823A Hot-climate version
S825A Radio control Oceania
S845A Acoustic belt warning
S850A Additional Export tank filling
S864A Retailer Directory Overseas
S880A On-board vehicle literature English
S887A On-board vehicle literature Arabic
S8A3A Sprachversion arabisch
S8KAA Oil-maintenance interval - 24 months/30,000 km
S8SMA Car ident. number visible from outside
S8SXA Prov.assignm.for Telematic/Online serv.
S8TCA
S8TLA Tagfahrlicht Front und Hech aktiv
S8TNA Tagfahrlicht über Lichtmenü
S925A Transport protection package
P955A Middle-East package
S993A model year code in VIN
S9AAA Outer skin protection
thank you all for your valuable help.
      10-05-2014, 07:12 PM   #9
aclockwrk
Drives: '15 M3 6spd
I also have dynamic handling so that probably needs extra power I guess.
In terms of installing the BMS S2. I have installed and uninstalled numerous times, just disconnect the main negative terminal on the big battery. When you reconnect it all you have to do is reset the time and date, everything else is still in memory.
      10-05-2014, 08:09 PM   #10
hatemax
Drives: BMW 550i
Thank you aclockwrk so much for the info
      10-06-2014, 10:55 AM   #11
Bavarian Tech
267
Drives: 335i
2006 330i  [10.00]
Only for N63 equipped vehicles n diesel's.
      10-06-2014, 01:04 PM   #12
hatemax
Drives: BMW 550i
Thank you Bavarian Tech for the confirmation, appreciate it.
      12-23-2015, 08:40 PM   #13
mert69
Drives: 530d
full picture ?
      12-23-2015, 08:58 PM   #14
ezmaass
ezmaass's Avatar
Drives: '17 650xi GC / '15 Audi R8 V10
Interestingly enough, my '14 550xi was in for service this week (~13k miles on the clock), and they replaced the battery. I was shocked (no pun intended). The SA said it was related to a BMW recall (or similar) action - batteries prematurely discharging? I've never had an issue with it, but I found it interesting that they were swapping these out. The car has only been on the road for 2 years and 13k miles. I've usually replaced batteries at around 5 years.
2017 BMW 650xi Gran Coupe | MSport | Exec Package | Driver Assist Plus | ACC Stop & Go | Adaptive Drive | B&O | Night Vision | Cold Weather | Active Seats
2015 Audi R8 V10 | Brilliant Red on Black | S-Tronic | Carbon Sideblades | Carbon Trim | Full Leather | Sport Exhaust | Illuminated Doorsills | I-Pod | Contrast Stitching
Previous: '14 550xi, '07 335i, '01 325i
      10-27-2016, 11:35 AM   #15
Assembler
Assembler's Avatar
Australia
Drives: F10 535d with Hartge bits
Sorry to resurrect an older thread.
However I'm now having active 4-wheel steering issues on my 535d F10 that I optioned up
The original batteries are 5 years old, so I understand that they are a likely cause.
I can get prices on the main battery from many after-market suppliers here in Australia ( sydney region)
However the smaller auxialiary battery is a mystery. The dealer hasn't told me what its specs are - anybody here able to fill me in?
Also is there any likely other culprits in the diagnostic chain that could cause this system to fail?
