2010 2011 BMW 5 Series Forum F10 Drain/replace coolant - how to drain? |
02-12-2020, 03:46 PM | #46 | |
Rep 2,591
If you only want to check for vacuum and don't mind bleeding the lines, Advanced Auto (maybe autozone as well) loan out pressure test kits for the cooling system. Should fit our cars. Keep in mind running pumps dry will affect the longevity of the pump, so might not be a great idea. Personally I'd go for the ebay one.
2015 BMW 535xi
02-14-2020, 07:43 AM | #47 | |
Rep 1,873
https://www.newtis.info/tisv2/a/en/f...oling/B9yoQmxG I have the tool, but haven't done the service yet. I'll probably be doing it this spring, not looking forward to it. I am interested in this different drain method - that's for sure. |
02-29-2020, 10:36 AM | #49 | |
Rep 965
How'd you get two gallons? |
02-29-2020, 06:27 PM | #51 |
Rep 2,591
Pretty much. You're not really pressurizing the tank, just displacing the water with air.
2015 BMW 535xi
03-01-2020, 10:02 AM | #52 |
Rep 965
Ok giving up on the method using the expansion tank, only got 2-3l for a second time. For you guys that took of the radiator hose, how’d you guys get to the E6? It’s so tight in there
03-05-2020, 11:57 AM | #53 |
Rep 2,591
Not sure how to get to the E6, but I would agree that you should just pull the hose. It's never good for a pump to cycle air.
2015 BMW 535xi
03-05-2020, 12:10 PM | #54 |
Rep 965
Which hose? The one with access from the the underbody? I tried pulling from passenger side hood, couldn't get the hose off even after loosening the two clamps.
03-05-2020, 02:45 PM | #55 | |
Rep 2,591
https://www.newtis.info/tisv2/a/en/f...check/B9lxHaR7
2015 BMW 535xi
Sylverlee150.00 Encendido397.50 |
03-10-2020, 10:53 PM | #56 |
Rep 199
Hey everyone, after poking around I think I got an idea. For those of you that do have the m sport package with the auxiliary radiators for the cooling oil. There is a coolant hose that easily disconnects. I'm thinking I can just use that as a drain and keep the car running while filling it up on distilled water to get all the old coolant out. After this I will drain the remaining distilled water and fill up the car with the correct coolant. Just my train of thought here.
03-11-2020, 09:14 PM | #57 |
Rep 229
What hose do you refer to? A picture?
2011 535i xDrive Black/Black, Michelin PS AS 4
2014 435i RWD Convertible Service Manual: www.newtis.info Part: http://www.realoem.com |
03-12-2020, 09:06 AM | #59 | |
Rep 2,591
The special tool is primarily for leak testing. It also saves dealers time because you don't have to bleed for 10 mins, but if you're DIYing, you can not use it and just run the bleed procedure.
2015 BMW 535xi
03-12-2020, 09:25 AM | #60 |
Rep 199
Here's the photo, I'm thinking to just let it hand and have it drain out coolant while the car is on. While the old coolant spills out I can just fill it up on distilled water to give a good flush.
03-12-2020, 07:34 PM | #61 |
Rep 2,591
I assume you're getting the car up to temp before yanking the hose? Otherwise, the thermostat might not actually open up.
2015 BMW 535xi
03-12-2020, 07:35 PM | #62 | |
Rep 199
03-12-2020, 07:36 PM | #63 |
Rep 199
The only problem I see is that the coolant won't reach the oil cooler, so my car might over heat. If that's the case then I will try to find another method
10-14-2020, 02:37 PM | #65 |
Rep 8
Does anyone else have a whole lot of extra hoses in the way? My car has the M-Sport with S840A High Speed Synchronization and the S823A Hot Climate packages. I'm not sure which combination of these it is but, so far as I've been able to see, my lower radiator hose looks nothing like the pictures I see on here. The outlet seems to be a plastic piece that elbows back up vertically along the radiator and is attached to the radiator with some form of a clamp (but not a hose clamp) that I haven't come across before. Of course, I closed it up before I remembered to take photos.
