2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Burger Tuning N20 Tuner for my 528i
      09-07-2012, 09:44 AM   #23
ryang79
Drives: 2012 528i
Sorry guys for not posting, I haven't driven the car a lot in the last few weeks. The acceleration response has definitely been improved. You can definitely feel the horsepower and torque gains. I feel this is the best mod that you can do for under $400 because you will actually feel the improvement right away!!
      09-07-2012, 10:29 AM   #24
PeterF11
PeterF11's Avatar
Netherlands
10
Drives: F11 5.28i
My N20 tune and BT cable have just been delivered
Will install the tune this weekend and will let you know the improvements.
@Ryang, I would really appreciate it if you can still send me that picture of how you installed the module on the right side of the engine bay. How did you pull the cable throught the rubbers? I am installing tomorrow so no pressure ;-)
Thanks!
PS I must live a very shallow life, being this happy with a tune
      09-08-2012, 03:07 PM   #25
PeterF11
PeterF11's Avatar
Netherlands
10
Drives: F11 5.28i
Have installed the tune today and it took me about 20-25 mins. Although the installation was easy, reconnecting the battery was a bit harder because i closed the lid and forgot that it does not open anymore after the battery is unplugged. Keep this in mind when you are installing yourself. Results of the tune are especially noticable around 3000 rpm. You can feel that it has more torque although the increase in hp does not feel significant. I might have to upgrade the firmware to the latest version. Anyway, it is easy to install, also for a non-technical guy like me, and not expensive so an easy choice to make.
      09-08-2012, 07:47 PM   #26
ryang79
Drives: 2012 528i
Sorry for the delayed response I have not been on much. Glad to hear you had an easy time installing the tuner minus the trunk incident. Yeah you can definitely feel the improvements around 3000. If you ordered from Burger the firmware should be up to date.
      09-15-2012, 08:14 AM   #27
HKe82
Hong Kong
Drives: F82
Any updates on how the tune is running? Cheers.
      09-16-2012, 01:05 AM   #28
PeterF11
PeterF11's Avatar
Netherlands
10
Drives: F11 5.28i
Tune is still running fine. However, you might want to strengthen the plastic part of the tune that drives the sensors. I did not properly block mine i. The engine bay, so it had room to flap about. After a couple of days, the plastic was severely damaged. I have now repaired it and covered it in two sponges to make sure this does not happen again. This is not a production flaw. It is just me not thinking this through well enough in advance. Last week i had to bring it in for servicing. I took out the tune, checked codes with the bt cable and brought it in. They checked it via diagnose equipment and i have had no remarks whatsoever.
      09-17-2012, 12:00 PM   #29
seajack0
Drives: 2012 528i xDrive
Can you feel the tune from 3k all the way up or does it seem to stop after a bit? Also, have you noticed your gas mileage being negatively impacted at all?
      09-20-2012, 01:29 PM   #30
PeterF11
PeterF11's Avatar
Netherlands
10
Drives: F11 5.28i
It pulls much harder from 3000 rpm. As mentioned, hp is not drastically different but torque is. Was racing a 535d today and although it was quicker, the difference wasn't significant. I shifted back into 3rd and could keep up with it. Considering the price difference here in the netherlands, i am quite happy.
      09-21-2012, 01:05 PM   #31
seajack0
just ordered mine! And no I don't think you're shallow because I too am excited. Perhaps we are just both shallow...
      09-27-2012, 09:53 AM   #32
seajack0
Installed in 20 minutes on Monday! This is a great tune for the money... you can really feel the added boost. Additionally, I've actually been getting better gas mileage. You now have more power on the lower end which sometimes negates the need to press harder on the gas. As others have said, you can really feel it 3k+. Where the car used to lose a bit of its power in this territory, it now feels much stronger.
I will be putting it up against my buddy's stock 535 at some point this weekend, will let you know how that goes!
      09-27-2012, 10:35 AM   #33
HKe82
Hong Kong
Drives: F82
Sounds good. Does it have different maps like the JB3?
And good luck against your mate's 535. Do let us know how it goes. Cheers!
      10-02-2012, 03:23 AM   #34
PeterF11
PeterF11's Avatar
Netherlands
10
Drives: F11 5.28i
@seajack, any news. Would be very interesting to ser how it compares to a stock 535i
      10-10-2012, 07:36 PM   #35
sgt_gman2005
G-MAN
sgt_gman2005's Avatar
Drives: 12 528i
2012 528i  [0.00]
2006 325i  [0.00]
1985 535i  [0.00]
subscribed for the N20 BMS stage 1
      03-16-2013, 06:02 AM   #36
moldcad
moldcad's Avatar
Poland
262
Drives: M235i
I'm bumping this rather old thread up, as I've owned a 2013 528xi since January and am planning on some tune to the nice but a little underpowered N20 engine... My questions to you guys:
- How is your Burger Stage 1 behaving after several months?
- Any knowledge on Stage 2 for N20 ?
- Anyone heard of the German Speed-Buster product, which is even simpler to install? If so, does it deliver?
TIA,
Piotr
      03-18-2013, 12:31 PM   #37
seajack0
I have had the BMS Stage 1 for the N20 installed for about four months now in my '12 528xi. I notice no problems with it and can definitely feel the difference when comparing it to my buddy's '13 328xi without the tune. You can really feel the increase in power between 1500 and 5000 rpm while traveling below 70 mph. Once you're up above 70, that's when I really feel that the n20 is underpowered, so don't expect too much more here. However, this is to be expected from a twin scroll 4 cylinder.
It was also very easy to install. I feel like it is a no brainer for $400.
      03-18-2013, 09:36 PM   #38
toberight
South Korea
9
Drives: BMW X7
Hartge Piggyback Ecu Installation & Dynojet
I SUCCEEDED INSTALLATION OF HARTGE CONVERSION KIT!!
MY 528i MY 2013
HARTGE PIGGYBACK ECU INSTALLATION & DYNOJET
PRE BASE DYNO AND POST INSTALLATION
I AM VERY HAPPY
      03-25-2013, 11:43 AM   #39
tinghei
Drives: f10 528i
Burger Tuning is the best, I'm getting better MPG and more HP on my 528i!!!
      03-27-2013, 11:38 AM   #40
joedimarzio
Drives: 2014 BMW 328i, Sport Line
Hi there, Is the battery of the 320i located in the same place? how do you do to disconnect? The diconnection is to reset the computer values?
Thanks so much
regards,
      06-03-2013, 06:46 AM   #41
Vitoco
Infidel
Vitoco's Avatar
122
Drives: iX3 LCI M Pro Carbon B
MY 528i MY 2013
I AM VERY HAPPY
And, how does it feel? Power/response increase etc.. tell us! and what did it cost?
Dec. 2022: Fully loaded Carbon Black G08 iX3 LCI M Sport Pro
Former: Glacier Ag. F31 328iA RWD M Sport oct. 2012, sold July 2022
| Sport Automatic | Adap. M Susp. | Pano. Moonroof | 20" ATS Racelight Grey w. Michelin PSS| M Sport brakes | Harman Kardon | Elec. Seats | PDC F&R | ACC Stop&Go | 335i MPE | Perf. Parts |
      06-04-2013, 08:46 PM   #42
toberight
South Korea
9
Drives: BMW X7
Someday ago, I have fight with Hyundai Sonata TGDI, MK6 Golf GTI stage II mapping ( dyno wheel 250hp ).
60 rolling drag Results. 2nd gear start. sport mode. no paddle shift
1st My car 528i (hi octane )
2nd Golf GTI MK6 stage 2 mapping (hi octane ) ( 1 car distance )
3rd Sonata TGDI (hi octane ) ( 3 car distance )
very good!
According to this result, My car 528i is faster than 535D.
And I think that my car is same result with G35
      09-23-2014, 08:24 AM   #43
pedro01
Drives: 2014 F10 528i M Sport
I just got mine - how the hell do you disconnect the plugs? I tried the first one and can't pull the **** thing off at all!
      01-23-2016, 01:09 PM   #44
wheresmy5
Drives: 2019 540i xDrive M Sport
Bump for more experiences with the Burger stage 1 for the F10 528... is the JB4 upgrade worth the extra $150 over the stage 1?
