2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding Tv module flash fail
      03-25-2022, 04:43 PM   #1
MartinSF
Drives: BMW F11 530D
Okay, so I changed out my dvb-t tv-module to a dvb-t2, so I, and the kids, can watch TV in the car.
I swapped it over and tried my luck to see if it worked. I'd didn't. I scanned for Channels and now it found several digital channels, but it says no signal.
I expected that, and went to esys (not launcher) to code it.
I detected Cafe for swe and coded it with success.
Same story, finds channels, but says no signal.
Okay, so I wanted to flash to same ilevel as the car.
I read vcm (I later tried read ecu), hw I'd from actual, calculated tal and so on.
Had the option to flash the TV module and proceeded.
It ended with failure. But why? What went wrong? I think it was the same story with an other TV module I tried 1 year ago ( it was the wrong non digital anyways, so I stopped after 1 attempt).
I have inserted the log. Any inputs are welcome.
Esys 3.30.
Enet cable
Picked rhe right i step shipment
I have Inserted pictures as well.
LOG:
Read SVT before TAL execution started.
ExecutionID=2022/03/25-19:05:12.265
[] prepareTALExecution started [PROGRESS]
[] prepareTALExecution finished [PROGRESS]
[] prepareVehicleForFlash started [PROGRESS]
[] prepareVehicleForFlash finished [PROGRESS]
[TV_MODUL - 4B] prepareECUforBLUpdate started [PROGRESS]
[TV_MODUL - 4B] prepareECUforBLUpdate finished [PROGRESS]
[TV_MODUL - 4B] authenticateECUforBLUpdate started [PROGRESS]
[TV_MODUL - 4B] authenticateECUforBLUpdate finished [PROGRESS]
[TV_MODUL - 4B - flsl_0000050c-005_000_027] Transaction type: blFlash; Message: TA started [TRANSACTION]
[TV_MODUL - 4B] performECUBLUpdate started with protocol UDS [PROGRESS]
MCDDiagService<id=56634, job=com.bmw.psdz.jobs.uds.MCD3_PerformECUFlashBL, service=RC_EM_IE - RoutineControl EraseMemory IndicatedErasing, description=error: negative response : conditionsNotCorrect, link=TV_MODUL_4B_ETHERNET> [DIAGSERVICE]
[TV_MODUL - 4B - flsl_0000050c-005_000_027] Transaction type: blFlash; Message: 0% progress on ECUId:TV_MODUL_0x4B [0% of flsl_0000050c-005_000_027] [TRANSACTION]
[] job failed with negative response error:
code: repeat job
description: Service RC_EM_IE returned a negative response with response code conditionsNotCorrect; LinkName: TV_MODUL_4B_ETHERNET
severity: ERROR
[THROWABLE]
[TV_MODUL - 4B - flsl_0000050c-005_000_027] Transaction type: blFlash; Message: TA finished [TRANSACTION]
[TV_MODUL - 4B] -MessageID is used multiple times, so MessageText may be ambiguous-job failed with negative response error:
code: repeat job
severity: ERROR
[WARN]
[TV_MODUL - 4B] - [Exception - TV_MODUL - 4b] job failed with negative response error:
code: repeat job
severity: ERROR
MCDDiagService<id=230634, job=com.bmw.psdz.jobs.uds.MCD3_PrepareECUforBLUpda te, service=DSC - DiagnosticSessionControl, description=error: negative response : conditionsNotCorrect, link=TV_MODUL_4B_ETHERNET> [DIAGSERVICE]
MCDDiagService<id=34617, job=com.bmw.psdz.jobs.uds.MCD3_PrepareECUforBLUpda te, service=CDTCS - ControlDTCSetting, description=error: negative response : serviceNotSupported, link=TV_MODUL_4B_ETHERNET> [DIAGSERVICE]
MCDDiagService<id=276649, job=com.bmw.psdz.jobs.uds.MCD3_PerformECUFlashBL, service=RDBI_RMA - ReadDataByIdentifier ReadMemoryAddress, description=error: negative response : requestOutOfRange, link=TV_MODUL_4B_ETHERNET> [DIAGSERVICE]
code: repeat job
severity: ERROR
[THROWABLE]
[TV_MODUL - 4B] There was an error during TAL execution, please check the log files. [WARN]
code: repeat job
severity: ERROR
[TV_MODUL - 4B] installECUBL started [PROGRESS]
[TV_MODUL - 4B] installECUBL finished [PROGRESS]
[TV_MODUL - 4B] finalizeECUBLUpdate started [PROGRESS]
[TV_MODUL - 4B] finalizeECUBLUpdate finished [PROGRESS]
[] There was an error, please check the log files. [WARN]
[] - [Exception - TV_MODUL - 4b] job failed with negative response error:
code: repeat job
severity: ERROR
[] finalizeVehicleFlash started [PROGRESS]
MCDDiagService<id=230900, job=com.bmw.psdz.jobs.common.MCD3_FinalizeVehicleF lash, service=DSC - DiagnosticSessionControl, description=error: timeout, link=HU_CIC_63_ETHERNET> [DIAGSERVICE]
[] finalizeVehicleFlash finished [PROGRESS]
[] prepareVehicleForCoding started [PROGRESS]
[] prepareVehicleForCoding finished [PROGRESS]
[] finalizeVehicleCoding started [PROGRESS]
[] finalizeVehicleCoding finished [PROGRESS]
[] finalizeTALExecution started [PROGRESS]
[] finalizeTALExecution finished [PROGRESS]
TAL execution finished [TAL_EXECUTION_FINISHED]
TAL-Execution finished with status: "FinishedWithError". [C207]
TAL execution finished. Duration: "3min 18s". [C206]
Read SVT after TAL execution started.
Read SVT after TAL execution finished.
