04-04-2012, 11:15 AM | #23 |
Rep 10,185
Would be great if brain surgery was as simple as turn everything off and press a lever for 3 seconds
BMW if you are reading, I need a job, Please. |
04-04-2012, 11:39 AM | #24 | |
Rep 2,612
Drives: F30 328i Luxury - Sport Auto
Gone: 2006 BMW E60 520d SE 6MT Gone: 2009 BMW E90-LCI 330d SE 6MT Current: 2012 F30 328i Luxury 8AT On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!) |
04-04-2012, 12:06 PM | #25 | |
Rep 51
Drives: 535ix
If you press a second time, then there you have it, ignition is like in the OFF position with a normal ignition key. Note: with BMWs cars, even after the S/S button is pressed twice, the car still is not completely off. It will go almost dead OFF, after around 15 minutes (don't remember the exact number of minutes).
2012 Mercedes-Benz C350 4MATIC Black/Sahara
2011 F10 535i xDrive MY 01/2011 Sophisto Grey / Black Last edited by gicamuci; 04-04-2012 at 12:12 PM.. |
04-04-2012, 01:06 PM | #26 | |
Rep 3,016
Where's the complication to find in that, I rhetorically ask . |
04-04-2012, 01:31 PM | #27 | |
Rep 339
Lifting the passenger side did work in the end, not sure what I did though. |
04-04-2012, 01:40 PM | #28 | |
Rep 4,047
04-04-2012, 01:43 PM | #29 | |
Rep 4,047
04-04-2012, 02:10 PM | #30 | |
Rep 3,016
I also just cleaned my car and, as per usual, I simply rotated the arms, on their lower pivots, through an angle of approximately 30⁰ and then hinged the arms towards the front of the car and into the vertical position as viewed from the side, i.e., well clear of the screen. Here's a handy hint for you: if when attempting to fold the arms forwards they still contact the rear lip of the bonnet, this indicates that you haven't moved them far enough - rotate them a few more degrees and try again I can only reiterate that I find this requires very little thought and I seem to be able to accomplish the task without any reference to instruction manuals. |
04-04-2012, 03:28 PM | #31 | |
Rep 339
04-04-2012, 03:55 PM | #32 |
Rep 3,016
04-04-2012, 04:31 PM | #33 |
Rep 339
Dunno, I haven't enabled or disabled anything recently that would cause a change in behaviour
10-03-2013, 10:08 PM | #34 |
Rep 31
Suppose you should not start wiper when windshield is dry. Not even talk about dirty and dry.... Now this process make us needs to "wipe" the glass to the vertical position in dry. Then after clean it... needs to "wipe" down.
I am lost... why make this thing so troublesome. |
10-04-2013, 05:04 AM | #35 |
Rep 29,202
Sometime when I wash the car, I can just pull them up, but this doesn't always work, anyone else tried this?
10-04-2013, 10:46 AM | #36 |
Rep 2,248
