2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding iPhone 5s Bluetooth issue
      09-20-2013, 08:22 PM   #1
pMart36
Drives: 2012 535xi M Sport
Is anyone else having issues pairing your iphone 5s? My F10 realizes that a device is trying to pair so it asks for the device code. However my iphone 5s and car cannot seem to pair. The car keeps saying there is an error and to retry. I tired for 30 minutes and couldn't figure it out. It's really frustrating because normally I am very good at these things. My car is a 2012 so I assume it has the most recent Bluetooth software.
I appreciate any help you can provide.
      09-21-2013, 02:59 AM   #2
kave
Sweden
19
Drives: BMW 520D Touring 2012
You can try an update at http://www.bmw.com/update
      09-22-2013, 08:23 AM   #3
eskdale
Drives: 520d M Sport Touring F11
My Car is also a 2012 but on checking via the iDrive it says that there is an update available. As the car has no signal at home I had to drive 10 miles to get some coverage. Tried to download via BMW teleservices - says it will take 9 mins - OK if gets to 89% and stops waiting another 5 mins in case it was going to continue. Repeated it again and stopped again at 89%. Tried with engine running and again stopped at 89% so having wasted over an hour decided to go home and try downloading to USB stick from www.bmw.com/update however as soon as you enter the 7th character of the last 7 digits of the VIN it says "The Vehicle Identification Number you entered is not correct. Please check your entry." It is most definitely correct - anyone else having this problem?
It worked last year when I managed to download an update
Thanks - Jon
      09-22-2013, 09:22 AM   #4
eskdale
Something changed on the BMW site as it has now accepted my VIN - Presumably they were doing some maintenance - Thanks Jon
      09-22-2013, 02:12 PM   #5
pMart36
I updated my software and spent another 30 minutes trying to pair. Still no luck.
      09-24-2013, 11:36 PM   #6
2k15f30
2k15f30's Avatar
Drives: 2015 335i M Sport
I have been having problems with BT since I started with ios7 beta over two months ago. While I've been successful in connecting I have not had much luck keeping it connected.
      09-25-2013, 12:52 AM   #7
Bowers
Drives: F10 2013
I've upgraded both the car's bluetooth software and the iphone 5 to ios7, and it works like a charm.
Not much help there, but at least you'll know the combination is possible
      09-25-2013, 10:16 PM   #8
pMart36
After several days, its finally working
      10-11-2013, 06:43 PM   #9
G_V_Black
Drives: 2011 X3 35i
What did you do to resolve the issue? I am experiencing the same problem in my wife's X3. BMW and iOS software is up to date, but my 5S still won't pair. Phone recognizes the car and vice versa, but the phone does not generate a pass key to complete the pairing process. Thanks.
      10-15-2013, 08:42 PM   #10
slownfast
Drives: 2013 528i Xdrive
I have no problem connecting it with iphone 5s. however, I waited for almost 10 minutes to pair it up. it works!
      10-19-2013, 12:09 PM   #11
pMart36
I just didn't give up and it finally worked. I also had to enter (create) a 6 number pin on the car before I entered it on my phone. I thought I only had a 4 number pin with my iPhone 4 but I could be wrong.
      10-23-2013, 09:09 PM   #12
G_V_Black
Drives: 2011 X3 35i
All set now😄. Possibly due to the iOS 7.0.3 update, but more likely because I was just doing it wrong from the start. As I mentioned in in my post, I was waiting for the iPhone to generate a passkey to enter into the car. I guess I had forgotten that it works the other way around 😳. Thanks for the replies.
      10-28-2013, 02:07 PM   #13
pdrf10
A Man of Wisdumb...
pdrf10's Avatar
Drives: 2011 F10 550i M Sport
Has anyone else noticed a problem with reading text messages via iDrive as a result of the iOS 7.0.3 update? I recently upgraded my iPhone 4S to a 5S, and have noticed the envelope icon no longer appears in the upper right corner of my nav display every time I get a new text message (nor does the message download via iDrive).
I re-paired the phone to the car over the weekend to see if it would help, but no luck. I guess we'll have to wait for BMW to come out it telecommunications software update UPD01007 to address the issue...
      10-29-2013, 01:17 PM   #14
LENELSA
LENELSA's Avatar
Drives: 2016 Audi A6 3.0 /BMW M240i
My wife has a 2013 535i.
How can I set up her iphone with car so it will read texts like my Windows phone ??
Is this possible yet ??
      11-20-2013, 05:47 PM   #15
pdrf10
A Man of Wisdumb...
pdrf10's Avatar
Problem solved via a tip in the following thread:
http://f10.5post.com/forums/showthread.php?t=914115
