2010 2011 BMW 5 Series Forum F10 Just bought a 550i and oh my do I wish I didn't.... |
09-13-2017, 01:27 PM | #23 |
Rep 312
Not for the injectors, for the coolant lines. It was actually part of a service bulletin but they also work on the 550i. Where the coolant lines go into the hard lines they sit right above the turbo and rubber just doesn't last through those heat cycles.
135i_vs_71.50 |
10-02-2017, 11:11 AM | #24 | |
Rep 697
I will do this RIGHT AWAY on the 550i. Thanks, |
badblack550xi464.50 |
10-02-2017, 11:42 AM | #25 |
Rep 2,416
thx for the PDF
2011 550i RWD 60-130 7.35
10-03-2017, 02:37 PM | #26 |
Rep 1,254
you will get this fixed and fall in love with the Beast
I have 2013 550 I had some issues with Drive train malfunction after replacing couple of coils and sparkplug car is running just fine. Good luck
10-03-2017, 03:52 PM | #27 |
Rep 659
10-04-2017, 07:27 AM | #28 |
Rep 697
I was looking at the M5 coolant lines compared to the N63, they are very different. Were the M5 heat shrouds large enough to cover the N63 hose and clamps?
10-10-2017, 10:29 AM | #29 |
Rep 48
Drives: '14 535i Msport, 99 M Roadster
Good Luck
Sorry to hear about your issues with the N63. I just traded my 2012 650i for a 2014 535i. I can now sleep peacefully at night.
Good Luck |
11-22-2017, 06:59 PM | #30 | |
Rep 2,062
Back more on topic, I have the same issue with the coolant hoses on my X5M as well.
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's '97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's |
11-22-2017, 07:32 PM | #31 |
Rep 2,062
Because the N55 doesn't have it's own set of issues Bulletproof BMW I6's stopped when they went from the M** to the N** engines.
11-22-2017, 08:44 PM | #32 |
Rep 5,362
11-22-2017, 09:02 PM | #33 |
Rep 2,062
Simple Google search netted me these results:
"BMW tech perspective here. The N55 is a better more reliable engine than the N54 was. Actually issues with the n55 are fairly few. On occasion I have had to do the HPFP, valvetronic motor, thermostat, and boost control solenoid. Cracked vacuum lines can cause low boost faults too. Oil leaks from the common areas include the oil filter housing and occasional oil pan gasket." "Both engines are good IMO. The main difference is the exhaust. The new N55 engine has one exhaust pipe the feeds from all 6 cylinder (for less fuel consumption) while the N54 had 2 pipes, one feeding from cylinders 1, 2, and 3 and another pipe feeding from cylinders 4, 5, and 6." I thought we'd gotten the GF a very reliable engine with the BMW I6 in her 08 535xiT, but after having to replace the engine myself last month after only 108k (failed injector flooded the engine and destroyed piston #1), more research showed me that the oil pump and/or piston failures are actually common (even found a YouTube video of someone disassembling their motor) and that the N55 isn't much different, proving this statement to be true: "Overall the N54 is a more complicated design. It also has some higher end components such as the piezo injectors and true dual turbos. N55 is what most would consider a cost reduced version of the N54." Point being it's still a BMW engine that's built with quantity over quality mindset, which seems to have been the other way around 15+yrs ago.
11-23-2017, 05:35 AM | #34 | ||
Rep 153
