2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications N63 Walnut blast?
      10-12-2017, 07:15 PM   #1
Bossman535
Drives: Alpine white
N63 Walnut blast?
Seen a member on one of the other forums recommend a walnut blast every 60k miles. Anybody walnut blast their n63? Or is it not necessary ?
Thanks
      10-23-2017, 01:46 PM   #2
addy27
Drives: F10 550i
Super expensive to do a walnut blast on the n63. The intake at the bottom makes it almost impossible to do it without removing the engine. I would rather recommend running with fuel system cleaners and the technique of running the car for 20 mins or so on the highway at 3k-4k RPMs to burn away any carbon buildup. Maybe Seafoam might be a better option for this engine.
      10-23-2017, 06:03 PM   #3
535_BiTurbo
Drives: 2012 550I - BMS Stg 1 & CAI
its direct injection maybe seafoam might be the best option
      10-28-2017, 10:58 AM   #4
Gpfarrell
Drives: 6MT Imperial Blue 550i M-sport
On direct injection engines, the fuel spray occurs inside the combustion chamber, down stream of the valves. Fuel additives won’t pass over the valves, so they’d be ineffective. Sea foam into a vacuum port should hit the valves... but I wouldn’t want to be the first to try it.
Walnuts were a miracle cure for our N54... it ran like a champ after the treatment.
