2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Raced my buddy's 2012 cls63
      07-24-2015, 02:27 AM   #1
Klolaylow
Drives: 2011 BMW 550i X drive
So I got a 2011 f10 550i x drive with active autowerk downpipes and exhaust with bms stage 2 vs my buddy's stocks 2012 cls63 & from a standstill it was no competition I would eat him all the way to 120 and we would slow down but from 60 & 80 mph rolls he would take me by half a car I wasn't running stage 2 aggressive mode just regular stage 2 with 93 fuel I was switching at around 5,800-6,000k rpm. Any one know if I run stage 2 aggressive mode and add a octane booster if I can take him than ?
      07-24-2015, 10:40 AM   #2
RSBro
RSBro's Avatar
Drives: 2012 550i M-Sport
From rolling you could try keeping your revs higher. IIRC the turbos on the N63 only kick in at 3k and most people I've read like to shift at 5k to get maximum torque before the band starts curving downwards.
But you're talking turbo vs N/A so he has no time to spool up like us to kick in that extra oomph.
2012 550i///M-Sport///Carbon Black Metallic///Oyster+Black Dakota///ZCV+ZLS+ZMP+ZPP+ZPS+ZSP+ZTP...M5 exhaust///iND Tricolor grilles///H&R Sport Springs///Turner Motorsport 12mm+15mm spacers
      07-24-2015, 01:49 PM   #3
FenixMike
Drives: 2014 BMW M5 Competition
Which engine does he have? Hard to keep up with those since some had a big engine, others had a blower or turbos. I have a couple friends with them as well and they are always talking trash to me, but I only have a piggy back.
I wouldnt run an octane booster unless it was Torco or a PROVEN REAL octane booster (nothing at an auto parts store is real). Torco is about $24 per bottle and will treat 10 gallons to bump 5 points or 5 gallons for 10 points (about 105 octane). If its not a tolulene based booster, its just BS and you will end up scattering your engine everywhere. You could also try a 35% of E85 mixed in (downside is you have to drive it for a while to let the fuel trims adjust and also for the knock sensors to allow for more timing) but thats a sketchy setup as it will also lean your car out and unless you have a scan tool or wideband you have no way to verify anything.
If you run straight 100 octane or an octane boosted equivalent you can add about 3 lbs of boost safely which pending the turbos not running out of steam up top, would give you about 30-40 horsepower gain.
2014 M5 Competition with ESS Tuning Flash
Gone but never forgotten...2015 X5 50i M Sport, 2015 550i M-Sport, 2015 M3, 2014 X5 50i M Sport, 2015 435i M Sport, 2011 550i, 2011 535i
      07-25-2015, 12:14 AM   #4
ARC550
Drives: M3, X5, 720s, X5, 750xi
Impressive!
My cousin has a 2012 CLS63 performance Pack with a are tech Stage 1 tune. He dynoed at 580whp and 624wtrq
I have a 2014 550xi with full catkess exhaust and custom ECU tune (maiine dyno - lowest reading dyno. Even lower then mustang at 490 HP which is like 550-560whp on a dyno jet. Anyway..
40-120 it's a draw and 120-160 he takes me by about 2-3 cars.
The AMG is a monster but at the end of the day I am AWD and he is RWD top end is inevitable !!
      07-25-2015, 04:36 AM   #5
Klolaylow
Originally Posted by ARC550 View Post
Impressive!
Oh wow yeah that amg is no joke when you had bms stage 2 did u often burn out a coil or is it only me that has that issue burnt 2 coils so far if so does anyone know any better coils than the Bosch ones ???
      07-25-2015, 10:08 AM   #6
Pimpsy
Drives: 2019 M5C
There is nothing a stage 2 kit does that will burn out a coil. If you are going thru coils, I'd look elsewhere for an explanation.
      07-27-2015, 01:18 AM   #7
Atlantis M3tallic
Atlantis M3tallic's Avatar
57
Drives: 2017 M3 ZCP
You could brake boost from a roll to help with the turbo lag.
      07-27-2015, 09:30 AM   #8
Ben2k9
Drives: 2011 BMW 550i M-Sport
I had the same problem with stage 2 and coils. There is definitely a link.
According to Terry at BMS, "If you have a faulty coil, plug, or injector, you're going to find out when you try to run Stage2 power levels"
So if this is true stage 2 is merely "revealing" a weak coil, but what's the difference if that coil would have worked perfectly fine for who knows how long without stage 2?
      07-29-2015, 10:25 AM   #9
ARC550
This is not a Evo lol You cant break boost these cars.. I know if tried.
Especially coming from built Jap cars.
      07-30-2015, 01:10 AM   #10
badblack550xi
badblack550xi's Avatar
i mean you can ive done it but takes a lot of practice
2011 550i RWD 60-130 7.35
      07-30-2015, 08:36 AM   #11
ARC550
Your full of crap!
      08-05-2015, 05:15 PM   #12
ellery
Drives: 2011 535i xDrive
The 2012 CLS63 is a Twin-Turbo 5.5L V8. Any ECU modification on that AMG and it'd destroy the 550 at any and all speeds
2011 535i xDrive | JB4 Stage 2 | VRSF DP | BMS Intake
M-Tech Kit | Hamann CF Lip
      08-05-2015, 05:46 PM   #13
FenixMike
its no different than chasing a CL500 down with an M5... mismatched cars. There are some good motor trend reviews of the new M5 vs the CLS63 and they are dead nuts even with the M5 having a slightly higher trap speed in the 1/4... a couple 550s on here are in stock M5 territory but you're right, modding a beast like that is deep in the 600s to the tires and out of 550i range without some serious work.
      08-15-2015, 05:57 AM   #14
Klolaylow
So thanks to badblack I raced my buddy's cls 63 again tonight this time I ran a 1/4 tank of 93 fuel with 2 cans of nos octane booster put stage 2 on aggresive mode and raised boost to 4.0 we did a few runs from a dead stop I would win by 3 cars, highway rolls we did 60 mph and 80 mph rolls till 135-140 and I would take him by half a car to a full car lol his reaction was priceless now just waiting on badblacks custom filter and some race gas and imma try the 1/4 mile
      11-07-2017, 03:58 PM   #15
535_BiTurbo
Drives: 2012 550I - BMS Stg 1 & CAI
Was it a PP CLS63?
