05-23-2019, 01:43 AM | #1 |
Rep 140
F10 Sunroof malfunction
Hello everyone! My f10 m5 is now having problems with its sunroof.
Most annoyingly it doesn’t tilt anymore no matter the sunroof is closed or not. Then I cannot open/close it by pushing the button to the end. That is I have to keep pushing the button to open/close until it stops. I have read the error code from app and it turns out 2 error codes which do not make any sense to me FZD 030215: SHD: invalid characteristic, no standardization available 030295: ESH: invalid characteristic, no standardization available Anyone has had this kind problem before? Any idea helps ***Problem fixed*** Because the battery was once replaced and the previous owner did not reset the sunroof properly, the malfunction appears Just simply press tilt for 15s and the sunroof will tilt *important: keep pressing the button til the sunroof stops moving itself, the process takes about 30s or more. The reason why I failed to reset before was I released the button at 15s. Hahha Last edited by rickyf10; 05-23-2019 at 04:54 PM.. |
05-23-2019, 07:52 AM | #2 |
Rep 79
I recently bought an f10 with sunroof and had the same problem. Mine likely come a lot during g a battery change, to reset it theres a set procedure but basically, press the tilt button continuously and let the roof go through a full open and close cycle, tilt, slid, the works. The roof them recalibrate itself or similar and should start working as intended. I might be able to find a link somewhere....
05-23-2019, 07:54 AM | #3 |
Rep 79
05-23-2019, 02:58 PM | #4 | |
Rep 140
Resetting sounds like a good idea and I’ve tried few times before. But thing is that tilt button doesn’t even work. I guess the word “reset” we say here is actually “standardization”, which is not available according to the error code. Have you checked your error codes? |
