2010 2011 BMW 5 Series Forum F10 reversing / back-up lights |
12-24-2012, 07:23 AM | #1 |
Rep 26
hi folks - loving my new F10 530d - really liking the car - comfortable, economical and powerful.
one thing though - the reversing lights are awful - very dim. I have to backup into the my driveway and live in the country where there are no streetlights so it is often pitch black at this time of year. Has anyone changed or 'upgraded' the lights - they are 16w "W16W" type bulbs - can we get better ones? Has anyone fitted LED replacements and did they work ok or throw the 'bulb out' warning? thanks in advance. |
12-24-2012, 07:40 AM | #2 |
Rep 144
Can't you just turn your fog lights on when reversing to give additional illumination? I've not noticed a problem with the reversing lights but I haven't reversed in the pitch black in a tight space.
Good luck. |
12-24-2012, 09:12 AM | #3 |
Rep 4,721
If you choose the led reverse light bulb, go for the cree R5 7 watt led. You can get them from ebay for around $20 pair.
Don't get confuse with cree q5 led bulb. The R5 is much brighter than Q5. |
12-24-2012, 01:42 PM | #4 |
Rep 3,834
12-25-2012, 08:52 PM | #5 |
Rep 158
i found some good ones in no code error.
http://www.v-leds.com
2016 X6 M PACK/MPPK
RACECHIP BLACK GTS RACECHIP XLR |
12-27-2012, 03:13 PM | #6 | |
Rep 26
Might have to do some more digging on the LED lamp front - although i wonder if even that will have any benefit? thanks again. |
12-28-2012, 11:03 AM | #8 | |
Rep 3,016
12-28-2012, 01:14 PM | #9 |
Rep 26
12-29-2012, 09:07 AM | #11 |
Rep 26
04-20-2013, 02:12 AM | #12 |
Rep 2
04-20-2013, 02:56 AM | #13 |
Rep 459
I think it's always going to throw an error code cause stock bulbs uses 21w and the LEDs uses 7w.
I also bought them. I'm going to see if mine throws an error code. |
04-20-2013, 07:41 AM | #14 |
Rep 3,834
04-20-2013, 01:24 PM | #15 |
Rep 158
http://www.vleds.com/6k-white-1157-11w-high-power-led-light-bulbs-1-pair.html
2016 X6 M PACK/MPPK
04-21-2013, 09:28 AM | #16 | |
Rep 3,834
Although it's not much of fire risk since the backup light doesn't stay on for an hour, compared to the angel eyes. |
04-21-2013, 09:47 AM | #17 |
Rep 2,003
You need resistors in parrellel. The lower the resistence the less it triggers the warning -sometimes 1000ohm is enough, I run 80R.
Also current draw must exceed 0.25A (there abouts, I forgot the exact) which is 3W. If these two conditions are not met, bulb warning is trigged. The ebay ones, some do not have resistors in parrallel, and some do not draw enough power. |
04-25-2013, 04:11 AM | #18 | |
Rep 2
04-26-2013, 12:47 AM | #19 | |
Rep 459
04-27-2013, 03:56 PM | #20 |
Rep 158
I didn't have any problems whatsoever , and didn't have any resistors or any code error.
2016 X6 M PACK/MPPK
04-28-2013, 09:53 PM | #21 | |
Rep 375
Drives: 2011 535i Sport - P1, P2
Anyone else here not a fan of the yellow turn headlight (the inside headlight that lights up when turning the wheel)? |
05-24-2013, 07:33 PM | #22 |
Rep 62
Got a pair of VLED reversing LEDs for 2013 550 and they throw a lamp warning! I asked with my order to have ones compatable with canbus but these were sent without comment. BOO!!
Now I have to fit my own resistors or throw away $40. I would steer clear of them if that's the customer service provided.
Best regards,
Don M Last edited by dmontg; 05-26-2013 at 05:45 PM.. |
