2010 2011 BMW 5 Series Forum F10 What did you do to your 5 series today? |
03-11-2021, 05:06 PM | #2201 |
Petrolhead
441
Rep 812
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
Big thanks to you for sharing those foglight delete covers!
2024 X3 M40i 2014 550i 2008 Z4 3.0si 6MT 2011 Z4 35si (sold) |
03-11-2021, 09:38 PM | #2202 |
Rep 2,595
2015 BMW 535xi
03-12-2021, 11:08 AM | #2203 |
Petrolhead
441
Rep 812
Thought about that, but I'd still have the two holes in the bumper where the original holder goes. Totally slipped my mind when I asked them to patch the holes at the bottom of the bumper to do those as well.
03-12-2021, 05:36 PM | #2204 |
Rep 1,156
i have a lip i'm putting on next week in gloss black. however my front bumper could use a refinish, so i may look into having it refinished and the lip sprayed, and molded to the front bumper for that clean look... |
03-12-2021, 06:31 PM | #2205 | |
Petrolhead
441
Rep 812
It's actually just attached with 3M tape in the front along the bumper and I have 4 holes drilled in the bottom to secure it with the same BMW plastic push-in rivets that are used on the rear diffuser. It looks super clean (and stock).
My concern with having it molded is always gonna come down to the fact that all lips, regardless of how careful you are, will eventually get scraped or dinged. It's much easier to unmount just the lip and have it refinished. But yeah getting your bumper refinished is like looking at a new car - definitely recommend it if you can spare the $$$. Quote:
03-12-2021, 10:25 PM | #2206 |
Rep 2,595
I forget who makes them, but there's a company that makes paint matched plugs that go into the holes. Not as clean or flat as not having the holes to begin with, but beats having exposed holes.
2015 BMW 535xi
03-13-2021, 09:48 AM | #2207 |
Rep 62
Finally able to find the time to do see upgrades on my 5. First off I got an Mtech kit with a CF diffuser, front lip, and trunk lip. Next I installed an Armytrix exhaust with an AR design catted DP, H&R sway bars, and an FTP CP.
Before the recent install, I had my 5 lowered on ST coilovers, 20" wheels, and jb4. Planning to get an IC and BM3 to run stage 2 and lastly upgrade headlights to Vision rings via Bavgruppe. It's my first build and enjoying the journey and the drive. |
03-13-2021, 12:34 PM | #2208 |
Rep 5,406
03-16-2021, 02:25 PM | #2209 | |
Rep 274
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #578262 as a referral.
F10 535i M-Sport | Gone but not forgotten: G01 X3 xDrive30i M-Sport; F15 X5 xDrive35i; E70 X5 4.8i |
spielnicht440.50 |
03-16-2021, 02:48 PM | #2210 |
Rep 1,156
03-16-2021, 04:15 PM | #2211 |
Rep 2,595
IIRC there is no high-flow DP that is CARB compliant on the market.
2015 BMW 535xi
03-19-2021, 11:47 AM | #2212 |
Rep 105
Added a trunk lip spoiler wrapped in gloss black vinyl, had the chrome strip on the door handles wrapped with the same gloss black vinyl, and then replaced the chrome fender turn signals with gloss black ones. I also replaced the license plate lights with some brighter ones, and also replaced the reverse light bulbs with some bright LED's.
I just received all the replacement LED bulbs for the interior of the vehicle, so I will be tackling that this weekend. |
AZ535i164.00 ezaircon4jc4551.50 |
03-19-2021, 03:58 PM | #2213 | |
Cole
322
Rep 498
03-19-2021, 06:11 PM | #2214 |
Rep 188
I second that!
03-21-2021, 08:07 PM | #2215 |
Rep 1,360
Front CV axle and differential fluid. The boot was pinched about 40K miles ago. I knew it will go bad at anytime. I inspect it at every oil service and it finally started to spray grease around the wheel a little so here we are. Not bad for 267K miles on original axle. Replacing just the boot is a cheaper solution but it takes about the same amount of time and is more messy so I opt for a new one due to high miles.
03-22-2021, 10:51 AM | #2217 |
Rep 2,595
What kind of rubber?
2015 BMW 535xi
03-22-2021, 05:57 PM | #2218 |
Rep 1,156
New Front Lip
New Trunk Lid Spoiler Dinan CAI New NGK Spark Plugs New Coil Packs New Radiator Trans Fluid drain and fill (filter and fluid was changed 4k miles ago) |
03-22-2021, 09:39 PM | #2219 |
Cole
322
Rep 498
They are 3/4" heater hose. Only cost about $1 per foot and super easy to change in the future. I am going to monitor them and see if they start degrading or anything. May possibly replace with something more permanent if they dont hold up long term.
03-23-2021, 12:01 AM | #2220 |
Rep 2,595
Are those oil resistant? The PCV system gets a bit oily sometimes, the first rubber hose I tried for my N55 started to get a bit nasty due to lack of oil resistance.
2015 BMW 535xi
03-23-2021, 11:31 AM | #2221 | |
Cole
322
Rep 498
I imagine,I will have to change them from time to time, but it's super easy to do with hose clamps and costs nothing. What did you end up using that worked better? |
03-23-2021, 12:28 PM | #2222 |
Rep 2,595
I used a nitrile rubber hose, original one I used was some natural rubber crap.
2015 BMW 535xi
