2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Car Vibration when Braking
      09-20-2011, 08:15 AM   #1
shaunlees
Drives: F10 525D
My F10 Has now been back to the Garage 3 times for new Discs (done 22000 miles) as I keep getting vibration through the car under normal braking. When they put new discs on they are fine for a few thousand miles and then the problem returns. You can feel a slight vibration through the car when driving too. Anyone else had anything similar? The car is great but this problem is really getting to me. Ive not had a BMW before, my last 2 cars were Lexus and absolutely faultless, BMW is so far proving to be a bad choice.
      09-20-2011, 08:40 AM   #2
blazex4
blazex4's Avatar
Drives: '14 Cayman S
It's usually the brake pads, did you replace those?
      09-20-2011, 04:53 PM   #3
rexus300
Drives: car
Check the rotors for warpage or runout. That will always cause vibration with breaking. While my Lexus was great it did also have vibration when breaking and the dealer corrected it by shaving the rotors to make it true again at 40k miles and the brake pads were replaced at 45k.
      09-23-2011, 11:22 AM   #4
Whipple
Whipple's Avatar
263
Drives: 2015 BMW M6 Gran Coupe
1 on that! Every Lexus I owned warped the rotors except my 92 sc400,after that all warped.You can have this problem on any car but will have to pay for a brake job.
2015 M6 Gran Coupe> DME stage 3 tune back end flash>JB4 with Methanol control>Fabworx Catless downpipes>Full Meistershaft GTC exhaust 102mm GB tips>Built motor with Forged Cp Carillo Rods and Pistons > SSP spec X clutch > Stage 1 Pure Turbos>PG front mount intakes>PG charge coolers>Vorsteiner front and rear Carbon diffuser>Auto Tecknic Carbon shift paddles>3D Design aluminum pedals
      10-12-2011, 05:26 PM   #5
Expatmarais
France
Drives: f10 535d MSport
Hi see general f10 forum for many comments on the vibration issue. You are not alone, sadly. I am still trying to resolve mine with a 3 change of wheels and 4 change of tyre brand. As for the discs, I was told after 3000 km that I had warped the rear discs... No idea how. Dealer said I must have been violently breaking at speed. Only time this happened was when ibrake kicked in on motorway automatically. Could it have been that in your case? Good luck anyway.
      10-12-2011, 08:03 PM   #6
KinG12sKy
KinG12sKy's Avatar
Cambodia
18
Drives: Evoque, RR Vogue AutoBio, M4
its the rotors i think.. you have to change those to solve the problem. I had the problem before and changing the rotors did help.!!
      10-13-2011, 04:01 AM   #7
lodewijkV
lodewijkV's Avatar
Belgium
Drives: Snowwhite
Do you by any chance wash your car when your brakes where hot?
Or maybe you did drive trough a puddle of water with hot brakes..
Both could de-form your discs because of the big difference in temperature.
It's just an idea because I've had it twice allready with my old BMW (e30) but no problems so far with the F11.
A friend of mine did have the same issue wit his M3 (e46), he changed the front rotors and pads and the problem was solved.
But it also came back after some time, no clue what the actual problem was because he sold it some time later.
      10-13-2011, 08:04 AM   #8
Vinfast
Drives: '14 550i M-Sport
Although BMWs are made with vents in the front air dam that are directed at the front brakes, they can still get hot. If you go through a car wash (heaven forbid) or wash the wheels, you should always allow the brakes to cool.
      10-13-2011, 07:47 PM   #9
ajherran
ajherran's Avatar
Drives: 2016 BMW X5
Your brake rotors could be getting corroded due to some outside source. Chlorine or salts can seriously corrode brake rotors and cause the vibration. One possibility.
      06-13-2013, 02:46 AM   #10
tmalakar3
Drives: BMW E46
Hi.
I wonder if you have what solved the vibration??
I have the same problem!
      06-16-2013, 11:47 AM   #11
olebrumm
olebrumm's Avatar
Drives: F10 525DA
I also had vibration issues.. replaced the front discs and got rid of the problem.. but my BMW technician told me that the problem could be that some bearings should be replaced or else the damage of my discs could happen again.. o_O
      06-22-2013, 01:47 PM   #12
scottz5
Drives: 13 F10 535xi & 11.75 E93 M3
Locking Caliper after 3 sets of rotors.
13 F10 535xi JB/B working on it
11.75 E93 M3 MR/Black Stock (wifey)
11 F10 535i AW/CB Mods Gone
      08-20-2017, 03:15 PM   #13
Mangas80
Drives: 530d f11
I have the same problem. Already 3 sets of rotors and pads changed. Problem is solved after changing rotors and pads but reappers after 5000km.
Calipers also checked. It seems they are ok.
Did you finally solved the problem? If so what it was?
Thanks
      09-01-2017, 07:30 AM   #14
corys530
corys530's Avatar
20
Drives: 2012 535i
Another thing to check would be the lower control arms, took me a while to find this on my X5
2001 530i
2004 330i
2006 X5 4.4 the beast
2014 328i
2012 535i
      12-23-2020, 07:40 PM   #15
KAOKAO
Drives: F10 M5
Exclamation Car Vibration when Braking
Hello I live in Taiwan, I have a BMW F10 ActiveHybrid5 (2012) with 80km/hr brake jitter problem. It was repaired 7 times in the BMW factory. They changed 3 sets of new brake discs,4 brand new aluminum rims and tires and one direction The machine during the repair process, it 's about 3200 kilometers the same problem reappears again and again every time. Does anyone have the same problem? How to solve the problem? thanks
      04-20-2021, 01:05 PM   #16
KaiserWil
Drives: BMW 520d
Hey! I have the very same issue, I had worn out pads so I changed the rotors also. I put on Zimmermann Coat Z rotors and Textar ePad pads. After 20k km, brake pedal started to vibrate while braking. So I took the rotors off and they were visibly damaged - circular dents on the inner side of both rotors. I installed new meyle rotors with TRW pads and it was smooth for maybe 5k km and then it again started. What could it be ? It vibrates only when braking. Did you have any luck finding a solution?
Picture of damaged Zimmermann rotors after only 20k km https://ibb.co/4NyDBrL
Thank you.
      04-28-2021, 10:26 PM   #17
Blue Angel
Blue Angel's Avatar
2016 XDrive 335d here, just purchased with 90k km (56k mi) and original brakes were pulsing badly.
Replaced with one piece aftermarket rotors and Bosch pads, and after only a few months of driving the brakes are pulsing, not slowing smoothly. This can be felt even at low speeds.
Has anyone figured this out yet? I'm wondering if one or more hubs are not machined true. If that were the case no new brake rotor will ever fix the issue.
      04-28-2021, 10:32 PM   #18
musclesmarinara75
musclesmarinara75's Avatar
2013 535 XDrive  [9.75]
Vibration while braking...even more with heavy braking, check those rotors
      04-28-2021, 10:35 PM   #19
Blue Angel
Blue Angel's Avatar
I bought the diesel for its economy, not for its speed I'm really easy on the car and let the transmission engine-brake the car in many situations.
Even being driven gently there's an issue with my brand new brakes after only a few months.
      04-29-2021, 07:33 AM   #20
Procommuter
Drives: 2014 BMW 535D
Had this same problem, when I replaced front control arms it stopped! still running same brakes.
      04-29-2021, 09:20 AM   #21
Unspec
Unspec's Avatar
1300
Drives: 2015 BMW 535xi
If you have a diesel, how are you engine braking?
2015 BMW 535xi
ISTA VM Setup/Tutorial
      04-29-2021, 06:30 PM   #22
Blue Angel
Blue Angel's Avatar
It engine brakes quite well, especially around town at lower speeds in lower gears. According to Wikipedia there are several ways modern diesels create effective engine braking:
https://en.wikipedia.org/wiki/Engine...ng?wprov=sfti1
I imagine with the advantage of a very flexible valve train, they could force the engine to operate in a similar fashion to the heavy diesels "Jake Brake" by releasing compression.
I drove truck during college as a summer job, and though the International 466 I drove didn't have a Jake Brake (and had less power than my 335d!) you could still get enough engine braking out of it to make it worthwhile downshifting on long hills to take some load off the service brakes.
