2010 2011 BMW 5 Series Forum F10 Offset question about Morr 8.2 |
06-20-2013, 07:32 AM | #1 |
Rep 24
Hi guys, I have an offset question about my 20" Morr 8.2, when I installed it last summer I immediately realized that the front wheels are 0.5-1.0 inch out from the fender and then I drove it for almost a year now. It drove fine and then in the past few months, sometimes just after I started the car (let's say for the first 5mins), the wheels will have large "gong" sound before complete stops. Then I thought it might be some brake dusts on the brake so I just put the problem aside.
Yesterday I took my car to BMW dealer for my yearly maintence and told my techniqian about this problem, he immediately said it's caused by the wrong wheel's offsets. He described the problem but it was too technical that I didn't quite understand (I'm a noob in wheels). He then asked me if my car feels retarted when making turns, I said well yes but I thought this is normal for changing to bigger wheels, it's most obvious when I make big turns then accelerate. He told me that this is because I have the wrong set of rims. He then describes this is like someone with size 8 feet but wears a size 10 shoes. Lastly he said my back wheels were out slightly as well but they were acceptable. When I look at the photos on this forum with aftermarket 20", I don't see anyone that has this issue. I'm quite sure that I cannot install KW V3 shocks because my car will definitely sit on the front wheels. This makes me frustrated because I spent quite alot on these wheels (>$3500) and I trusted Morr that they said they have exclusive offset details that will not expose to the public. Basically I came out with a few options and hopefully you professional can help me out. 1) the techniqian knows nothing about aftermarket wheels and I'm overly sensitive, the wheels are normal and should run fine 2) Morr did this offset on purpose to give the car an aggresive look 3) I'm the unlucky one to get a defected wheels with wrong offsets or Morr sent me the wrong set of wheels at the beginning Sorry for long post and thanks in advance for your response. |
06-20-2013, 10:01 AM | #2 |
Rep 24
06-20-2013, 11:10 AM | #3 |
Rep 240
I think you may have a suspension issue unrelated to the wheels themselves. I'd double check and see if the H&R springs were installed properly, the noises you describe are in-line with springs that are not settling properly, perhaps a shifting spring pad. This problem would get worse with time as the pad would get worn down by the improperly positioned spring.
Thanks for the pics, from what I can see there is nothing wrong with that setup. The first picture just outlines the more aggressive front offsets we tend to utilize on the F10 but unless you are rubbing tire against fender there should be no other issues that'd be caused by the wheels themselves. |
06-20-2013, 01:20 PM | #4 |
Rep 24
hi Cal, so what you're suggesting is the suspenion problem (not install properly)? Some of your terms are so technical and i dont quite get it. Do you actually mean if i ask someone to reinstall the front springs will solve both wheels coming out from fender and the brake sound issues? Thx
06-20-2013, 04:24 PM | #5 |
Rep 8,279
Just my two cents but the 20x9 VS8.2 have a pretty conservative offset and I've added 12mm spacers to push them out flush to the fenders. From the looks of it your car looks higher then normal F10's i've seen with H&R springs.
06-21-2013, 05:16 AM | #6 |
Rep 29,202
When you lower the f10 (more than you have though), the front wheels cambers in a lot.
06-26-2013, 02:34 AM | #9 |
Rep 24
Hi Cal and Carlos, the techniqian at BMW told me today that he had disassembled the front wheels and saw the H&R springs were installed properly. Do you have any ideas that caused the problem?
