2010 2011 BMW 5 Series Forum F10 bmw f07 underseat subwoofer upgrade |
02-08-2015, 02:06 PM | #1 |
Rep 13
hi there
any one can help with the connection for underseat subwoofer, i bought the Ampire neo 8 subwoofer, i thought it is just plug and play , but BMW original harness or connector is 4 pin and it is only ( positive and negative ) on the new subwoofer, any one please can help with the connection required and from where i can buy it ( from 4 pin connector to positive and negative) thanks |
02-11-2015, 08:07 AM | #2 |
Rep 14,522
There might be an aftermarket adapter you can use...might have to search or Google it? Is there a significance upgrading to those subs you purchased? Let me know if they fit because I heard 8's should fit but someone measured the stock woofer and it's 6" woofer but the housing will accomodate an 8".
02-12-2015, 02:34 AM | #3 |
Rep 13
i bought the Ampire NEO8 subwoofer, it is the same size as the OEM ones except from the wiring , but i figured out how to do the wring , you just buy connector and pins from BMW , to connect to the original car connector, didn't try it , but i hope it will works
02-13-2015, 10:08 AM | #6 |
Rep 13
well, i have the base system which i believe no amp, i upgraded the 4 door speakers with 2 tweetrs all plug and play ( BMW top hifi speakers) and i bought the neo subwoofer and it is big improvement in sound
02-14-2015, 10:26 PM | #7 |
Rep 126
Drives: 2013 528I M Sport
Well I know you spent the money but BAV sound will have a Sub Upgrade within the next 2 months.. You may want to shoot them an email about an adapter those guys would know
02-15-2015, 08:28 AM | #8 |
Rep 14,522
03-13-2015, 11:46 PM | #9 |
Rep 359
03-16-2015, 11:22 AM | #10 |
Rep 9,097
Waste of money if you do not amp underseats. Unfortunately OP lacks knowledge in beamers and tries to cut corners where feasible.
You put SWS-8 / Jehnert there and it will burp as CIC / NBT is not good enough to power them.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
03-17-2015, 04:35 PM | #11 |
Rep 994
need to add/upgrade amp. otherwise, it's a waste of money.
iPhone 6 Plus (iTunes library/iTunes radio/Waze, etc) to Airport Express via AirPlay. Toslink out of Airport Express to Helix P-Six DSP. PHD AF 1.C tweeters, PHD FB 4.1 midranges. Jehnert Door Cards and mid-bass'.
03-18-2015, 04:09 PM | #12 | |
Rep 1,126
