2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wash, Wax, Detailing and Cosmetic protection/repairs Bird poo etch!
      06-12-2016, 12:48 PM   #1
Apples12
Drives: 520D LCI auto
Bird poo etch!
Help!!
Had some birds drop a load on the boot lid and passenger door, wiped it off and had car washed but it's left an etch in the clear coat
How can I get this out?
I've got meguiars ultimate compound which was recommended, this has knocked it down a fair bit.
I've also got some g3 paste wax to go on the car once our weather sorts itself out
Any tips?
      06-14-2016, 09:59 AM   #2
snj1013
Drives: 2011 528i
Some pics would help, but likely you won't be able to make it disappear. Wet sanding with some 3000 grit sandpaper may help, but only take this step after some less aggressive measures. You might check with some detail shops and see if they can help as well.
      06-20-2016, 12:59 PM   #3
Dowsey666
Drives: 2013 520D
Hi Newbie here this being my first post. ok just got my hands on a 2013 F10 520d and I love it. When I was cleaning it the other day I spotted some faint scratches and blemishes in it so like yourself I treated it to a bit of meguiars ultimate compound which I did by hand. yeah it did ok but not great so looked on line and decided to go with their DA polishing system complete with all pads. Tried again first by claying it down using dodo juice and their clay bar, then used the compound then changed pad then used auto glym paint restorer and then finally meguiars gold class wax and I have to say it did a bloody good job with getting the scratches and blemishes out. Luckily never had any issues with bird poo, hope you get it sorted.
      06-28-2016, 03:56 PM   #4
dadysev
dadysev's Avatar
Montenegro
169
Drives: Man
For starters watch this:
http://f10.5post.com/forums/showthread.php?t=1224538
Then watch some more of his videos. All your questions will be answered.
also golden rule 10% products 90% technique and elbow grease.
      10-15-2016, 09:09 PM   #5
Quicksilv3r
Quicksilv3r's Avatar
Drives: 2013 BMW 535i M-Sport
Menzerna 3-in-1 w/ Uber orange pad
-WJV
      11-15-2016, 10:34 AM   #6
jihwan0212
Drives: E92 M3
Hi guys, I have a similar problem. I got my 535i a few days ago and recently noticed some white 'water' spots on the left tail light. (
View post on imgur.com
) I put some pictures on here to see. It was really bothering me so I tried a couple head light restoration products and meguiars scratch removal with no luck. Any ideas on how to remove these spots? Thanks
      11-15-2016, 12:57 PM   #7
snj1013
Drives: 2011 528i
I would suggest going a little more aggressive with the polish. The plastic lens can be polished just like paint, just make sure not to use any waxes on the lens. You should be able to use a sealant to protect the surface after polishing.
There are also products designed for plastic, but if you have some paint polish, I would try it first.
      11-15-2016, 04:22 PM   #8
Originally Posted by snj1013 View Post
...The plastic lens can be polished just like paint, just make sure not to use any waxes on the lens. You should be able to use a sealant to protect the surface after polishing.
Why not?? I've been waxing the plastic lenses for decades...
      11-15-2016, 11:01 PM   #9
claykin
Drives: various BMW
BMW oem paint on the F10 will include self healing clear.
Clean up the bird poo, then leave car in exposed sunlight for a couple days. Etching Should disappear.
2023 840GC | 2021 740i | 2019 X3
      11-16-2016, 03:46 PM   #10
snj1013
Drives: 2011 528i
Wax can sometimes white stains on plastic surfaces.
      11-16-2016, 09:58 PM   #11
EuroDude
Drives: 2017 GT350
2017 Ford GT350  [0.00]
Originally Posted by Apples12 View Post
Help!!
Any tips?
Your Meguiar's compound is good. Bird poop however, if etched into the paint as you say, has several levels of nastiness. Your clearcoat is as thick as a post it note. If you remove too much clear around the problem, you will end up with a bigger problem - clearcoat failure, then you're toast. PS: Your paint won't self heal anything.
      11-16-2016, 11:30 PM   #12
Interesting.... Never heard that before. Could it be the quality of the wax?
      11-18-2016, 08:57 AM   #13
snj1013
Drives: 2011 528i
I think it has more to do with how porous the substrate is. I'm sure you've seen what wax can do to rubber trim, causing white stains. Same problem can occur with plastic. My guess is that if the plastic is in good shape, and not dried out/porous, you probably won't have an issue. I just use pure polishes to polish plastic and then seal with a synthetic sealant.
      11-18-2016, 12:56 PM   #14
Makes sense and I never thought of it that way. I guess I've never had that issue. I generally do use polish only on the lenses and when I do the paint correction I stay away from the plastics.
Thanks!
      11-27-2016, 10:54 PM   #15
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Never heard of self healing clear
