05-27-2017, 02:00 PM | #1 |
Rep 40
Scratch Removal
Look what I found at Auto Zone. I had been practicing on my '04 Dodge Ram.
Do not use 1500 grit sanding sheets unless you are a glutton for punishment. All those compounds and polishes that say they remove up to 1500 grit...I say b*&%Sh#t. Maybe if you use a rotary with wool. I followed with 2000 and 3000 and still had work. Overall though my results were great. Truck had a ton of scratches. I'm about confident enough to step up to the Bimmer Last edited by 740boy; 05-27-2017 at 02:08 PM.. |
05-28-2017, 01:39 PM | #2 |
Rep 14,521
wait...so did you use a DA polisher when you used the compound products? i used CG's V line with great results!
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg Last edited by lsturbointeg; 05-28-2017 at 01:44 PM.. |
05-29-2017, 01:06 PM | #3 |
Rep 40
Yes i used a DA, Meguiar's, Griots, and PC. I broke out the yellow pad but that was too extreme. I first tried Menzerma 400 still could see fine sanding marks. Went from there to M105 and finally what I call rocks in a bottle...M100. The M100 with orange pad did the trick. Followed with M205...lovely.
01-23-2018, 01:41 PM | #5 |
Rep 878
Red pad? Aren't those typically used for sealants (no cut)? Griots BOSS Correcting Cream is good stuff though. Use that or Menzerna.
-WJV
