2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Headlight Vertical Adjustment
      09-20-2011, 11:58 PM   #1
taylorpetie
taylorpetie's Avatar
Drives: G80 M3CX, F10 550i X-Drive
Hi there. My headlight on the passenger side seems slightly low and would like to adjust the vertical height. I want to confirm (from pic below) that the arrow pointing to the hex screw is the one that adjusts the vertical height? Can someone please confirm before I muck with it? And is it clockwise that raises it or CCW? Thanks.
      09-21-2011, 02:37 PM   #2
bimmertaxi
Norway
Drives: F10 525d
2014 BMW 530d  [0.00]
2010 BMW 525d  [0.00]
Make sure the light switch is set to position 2 before adjusting if you have the adaptive xenons, as the Auto setting affects both height and width of the beam pattern.
      09-21-2011, 03:05 PM   #3
taylorpetie
I would had never known that and I do have the adaptive xenons. Thanks for the guidance.
      09-21-2011, 05:50 PM   #4
BMW1
Drives: 528i
I need to do this also what is pos 2
My light switch 1 to left is auto 1 to right is parking 2 to right is headlights
adaptive is only to left pos 1 auto, and is up adjustment clockwise
      09-21-2011, 10:29 PM   #5
taylorpetie
Two to the right is pos 2. clockwise was up adjustment.
      09-29-2011, 11:32 PM   #6
taylorpetie
Hi Bimmertaxi. question: so I adjusted with the light in position 2. As days go by, I realized I positioned it to high... so opened the hood and did several adjustments over a period of time... BUT i freakin forgot to move the light switch to position 2 (i.e. left it in Auto setting) and probably affected the width of the beam (how to confirm?). If I turn clockwise, does it make the beam width smaller or larger?
      09-30-2011, 02:05 AM   #7
bimmertaxi
Norway
Drives: F10 525d
You really should use a headlamp aimer for this job.
When the headlamps are in auto mode it depends on the angle of the steering wheel, the speed of the car and a couple of other factors how the headlights will turn.
Your BMW service center shouldn't use more than 5 minutes to get this right.
I don't know any details on how to adjust the headlights.
Edit: I don't think the beam width of the individual headlights are adjustable, but the combined beam will be affected.
      11-05-2013, 04:17 PM   #8
The X Men
Drives: 2013 X3 35i
I figure I revive this old thread instead of starting another one. The headlight height screw is a 6mm hex screw, does anyone know what the 2.5mm hex screw does in the center of that 6 mm height adjustment hex screw? I adjusted the 2.5mm by accident, but I counted the turns and I think I got it back to its original position.
      11-08-2013, 07:13 PM   #9
shikbas
Drives: Bimmer
So my question is that both lights will go up with clock wise rotation?
Thanks
      11-09-2013, 07:46 AM   #10
The X Men
Drives: 2013 X3 35i
Yes CW up for both.
      11-09-2013, 08:06 AM   #11
shikbas
Drives: Bimmer
Originally Posted by The X Men View Post
Yes CW up for both.
Thanks
