2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions F10 LED Cornering light Upgrade retrofit
      01-19-2020, 06:29 PM   #67
NZ-M340ixDrive
New Zealand
27
Drives: 2020 M340i xDrive
My LED Canbus adapters still bring up an error code? Can I use them and use bimmercode to code out the cornering light so the LEDs work with no error code
335i DCT - Sold
M5 DCT - Sold
M140i Top mount big single - RIP
M340i xDrive Top Mount big single in the works
      01-19-2020, 06:33 PM   #68
marmit2017
marmit2017's Avatar
Drives: 11 535i 13 328i xDrive
You should be able to. But when you code it out you'll code out the high beam bulb, even though there's no high beam bulb.
      01-19-2020, 06:40 PM   #69
NZ-M340ixDrive
New Zealand
27
I'm keen to do that I don't mind how do you do it mate?
335i DCT - Sold
M5 DCT - Sold
      01-19-2020, 06:44 PM   #70
marmit2017
marmit2017's Avatar
I've coded mine through Carly, but I assume it's similar. It's in the FRM and you'd just turn off the voltage check monitoring.
      01-19-2020, 06:46 PM   #71
NZ-M340ixDrive
New Zealand
27
And that will do the cornering lights too?
335i DCT - Sold
M5 DCT - Sold
      01-19-2020, 06:48 PM   #72
marmit2017
marmit2017's Avatar
Yes. There is no high beam bulb on our cars because of the bi-xenon setup, assuming you have bi-xenons and not halogens. The cornering light takes place in the housing for the high beam. If there is an option to disable cornering light voltage I'd do it too
      01-19-2020, 07:20 PM   #73
NZ-M340ixDrive
New Zealand
27
Legend!
It's an M5.
I just coded out the high and low beam voltage and no error.
Thanks mate. Also changed my D1S to 6000k
Appreciate the assistance mate!
I don't mind the error code not being there I'll know if the bulb is dud I'll see it won't be as bright!
335i DCT - Sold
M5 DCT - Sold
      01-21-2020, 07:16 AM   #74
marmit2017
marmit2017's Avatar
Legend!
It's an M5.
Legend!
It's an M5.
Nice!! Which bulbs did you use? I feel like the stock xenon bulbs aren't that bright. Did you notice a difference?
      01-21-2020, 10:35 AM   #75
etnsandman
Drives: 2015 M5 Competition
Bimmercode can also make the required coding changes. I need to do this mod as well.
      01-21-2020, 11:43 AM   #76
NZ-M340ixDrive
New Zealand
27
Legend!
It's an M5.
Legend!
It's an M5.
Yeah noticed a difference.
The led I used were GT ultra 5700k LED
The D1S I used osram cool blue intense 6000k
I just hope the demons get slightly brighter with use!
I also used bimmercode to make my halos 100% brightness
[IMG][/IMG]
335i DCT - Sold
M5 DCT - Sold
      01-23-2020, 12:50 AM   #77
M@@L
Drives: BMW 2012 535XI
YES THAT CORRECT
      01-23-2020, 11:34 AM   #78
David_Vasha
David_Vasha's Avatar
Drives: 2011 535i XDrive
How are we still talking ab this
      01-23-2020, 12:42 PM   #79
Sunny 528i
Drives: 2012 528i
For anyone that wants to use E-Sys to turn off the error message from LED cornering lights:
Make the following updates in the "FRM" ECU
For LEFT Front cornering light
AUSG_09_FL_WARM_WEBERW_AKTIVE
Aktiv -> Nicht_aktiv
AUSG_09_FL_L_KALT_WEBERW_AKTIVE
AUSG_09_FL_L_IS_LED
Nicht_aktiv -> Aktiv
For RIGHT Front cornering light
AUSG_10_FL_R_WARM_WEBERW_AKTIVE
AUSG_10_FL_R_KALT_WEBERW_AKTIVE
AUSG_10_FL_R_IS_LED
I swapped halogen to LED without using any additional cables. Updated FRM ecu and coded to vehicle. No more errors on dash from cornering LED's.
      02-03-2020, 02:44 AM   #80
marmit2017
marmit2017's Avatar
Legend!
It's an M5.
Legend!
It's an M5.
[IMG][/IMG]
Where did you purchase the d1s bulbs from?
      02-03-2020, 02:14 PM   #81
NZ-M340ixDrive
New Zealand
27
For ppl who are doing the transition to LED you sound like a whining bitch
335i DCT - Sold
M5 DCT - Sold
      02-06-2020, 01:47 PM   #82
Sunny 528i
Drives: 2012 528i
Im sure David_Vasha is still upset from failing his state vehicle inspection. Let's cut him some slack.
      02-06-2020, 09:43 PM   #83
marmit2017
marmit2017's Avatar
Bc your dumb ass comments keep bumping this thread lmfao
      02-19-2020, 01:27 AM   #84
David_Vasha
U got me boss Man U right
      02-19-2020, 01:28 AM   #85
David_Vasha
Damn bro I was just talking ab the damn unspec guy and his crazy light speech.
      02-19-2020, 01:29 AM   #86
David_Vasha
Thanks for cutting me some slack buddy I appreciate it
      03-03-2020, 10:36 PM   #87
Grizzlymc
The Hibernator
Grizzlymc's Avatar
Drives: 2018 X3 M40i
Bump
      03-09-2020, 12:26 AM   #88
Grizzlymc
The Hibernator
Grizzlymc's Avatar
This was a fun read. For those who are actually still interested in this and not pointless internet trolling...
1) I found the easier way to get the locking bulb harness in place is to slip one hand in with your palm facing you, then slip the other hand directly in front of it with the back of your second hand against the palm of your first. Use your index finger to apply pressure against one of the locking tabs and the other index finger against the other tab.
2) there’s no way to code out the flicker. You need to buy a resistor 6ohms or an adapter like this one
HIKARI Pair LED Conversion Kit Headlight Canbus Error Free Anti Flickering Resistor Decoder - H7 https://www.amazon.com/dp/B07688V7V9..._xkDzEbS69WJKS
3) you may have to code out the malfunction light depending on the led you installed. This shouldn’t be a problem because the warm and cold monitoring is for halogen lights. Code the cold and warm monitoring for high beams to inactive. The high beams on the f10 represent the cornering lights because of the light wells location being standard high beams on older models. Yes the actual high beams are in the same outer well as the xenons.
