2010 2011 BMW 5 Series Forum F10 RaceChip Ultimate Install Pictures for 535i (F10), aFe Scorcher, BMS Stage1 Thoughts? |
12-11-2014, 05:25 PM | #1 |
Rep 85
I'm thinking about buying a RaceChip Ultimate. Does anybody here have any installation pictures for a 535i (F10). Just wanted to know out of curiosity what the actual installation entailed.
I installed an aFe Scorcher and it is just a basic two connection TMAP/MAP sensor setup like the BMS Stage 1. I really like the "feel" of the car now. No, I didn't get any dyno runs on it. I only installed it two days ago in the rain, as the sun was going down in a parking lot freezin' my arse off. Did a couple of highway full throttle runs and from some from a dead stop both in regular and sport mode. If definitely pulls a lot harder and it hits the 7000RPM mark much faster. Could not really tell much difference running it in normal drive mode and sport mode. Felt about the same - still way better than stock. Also, has anybody tested the three tunes on the same car - RC Ultimate, aFe Scorcher and BMS Stage 1? If so, what did you think about each one? Thanks in advance! Last edited by TShoot; 12-11-2014 at 05:27 PM.. Reason: Spelling error |
12-15-2014, 09:27 PM | #3 |
IG @bmwF9xG80
3813
Rep 7,593
This is what RaceChip sent me but my engine is different but hope this helps and gives you an idea.
I am going to let the RaceChip X5 folks know of your thread so they can chime in. I looked over at the aFe Scorcher and BMS Installation to see which one guides me the best. Your previous aFe installation will help as RaceChip only plugs into 3 sensors.
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
12-15-2014, 10:01 PM | #4 | |
Rep 85
Stock boost on 535i is about 8 PSI as a reference. |
12-15-2014, 10:11 PM | #6 | |
IG @bmwF9xG80
3813
Rep 7,593
Familiarize yourself and see what you think.
12-15-2014, 10:16 PM | #7 |
Rep 85
Oh, and mine did not have the easy to snap off clips on the air filter box.
It has 6 #T25 torx screws to get to the MAP sensor behind it. Not a big deal, but the aFe Scorcher directions had me take off more that I really needed to. |
12-16-2014, 07:02 AM | #8 | |
Rep 85
Not really worried about it since it looks like it only has two connections like the aFe. If I have time, I'll document the installation with better pictures. All depends on the weather since I'll be doing it outside. Really surprises me that the installation instructions are so bad but I guess they have to cover so many vehicles that you couldn't spend much time properly documenting each one with decent pictures. ROBNYC, thanks for your pictures. Did you install yours yet? Impressions? |
12-16-2014, 07:55 AM | #9 | |
IG @bmwF9xG80
3813
Rep 7,593
I looked at aFe and BMS install took the idea from there, then I noticed RaceChip only plugs into 3 sensor/socket in my car. aFe plugs into 2. So it should be straight forward for you, you should definitely see if oPasha can help you as well and write an Installation guide Yes RC installation guide isn't all that helpful since they're mostly known in Europe and their installation seems to be used by folks who know what they're doing already. I am going to write a Installation Guide soon with pictures and videos for RaceChip on the N20 engine. I sent Opasha pics and videos so we were finding the best way to do it and I am waiting to have time during day light to install but its been too cold lately so hopefully today or tomorrow.
12-16-2014, 08:39 PM | #12 |
IG @bmwF9xG80
3813
Rep 7,593
Can you take a picture of the harness connectors on your car (close-up) to see how they look ? The one on the throttle body is what I'm trying to compare to mine.
So RaceChip says only connects to 2 places ?
12-16-2014, 10:46 PM | #13 |
Rep 18,712
Guys, I believe, the 3 connector is for the N20/N26 setup. While the N55, only uses the TMAP and MAP sensors.
All these different brands, they all uses the same sensors and similar configuration. I have 528i where I have to plugged in all 3 sensors + 1 pneumatic wastegate solenoid when I had the BMS Stage 1. But when I moved to the BMS JB4 Stage 2, I only need the TMAP, MAP, and the Pneumatic wastegate solenoid sensors plugged. While on my X5 35i, BMS Stage 1 and BMS JB4 Stage 2, I only need to plugged in the TMAP and MAP (No Wastegate, since it is Electronic version, but I added the EWG harness on my JB4 Stage 2). I may be wrong, but those are my summary from seeing all of these different companies tuning installation instructions.
12-17-2014, 08:35 PM | #14 |
IG @bmwF9xG80
3813
Rep 7,593
@r33 is right
@Tshoot View my installation pics today
12-18-2014, 05:33 PM | #15 | |
Rep 85
The strange thing, and what confused me at first, was that the aFe module harness has similar looking connectors for the TMAP and MAP sensors but had to be plugged in specifically to one or the other based on the color of wiring on the aFe connectors. The RaceChip came with the two connector harness but no indication of which one needed to be plugged in to the TMAP and MAP sensor. When I called in, they said it didn't matter which connector I plugged into which sensor, it would "auto-detect" and work just fine. r33, I have never had a BMS Stage 1, could you just plug the connectors into either the TMAP or MAP sensors without regard to which connector it was and it would "auto-detect" or did you have to plug a specific connector into the TMAP sensor and the other to the MAP connector by wire colors? For the RaceChip module, it had very, very limited info out of the box with regards to installation instructions for the 535i. Mine were not color coded at all like yours ROBNYC. I just got a clear bag with a harnass in it and that was it. When I get a chance, I'll take pictures. I have to take the car in for service on Monday so I won't get a chance to install the RaceChip until after that. Also, still need to take off the aFe first. :-) Going to miss that extra kick from the aFe but hopefully the RaceChip will surpass it when finally get to put it in. |
12-18-2014, 05:42 PM | #17 |
Rep 18,712
@TShoot, it has to connect to the correct TMAP or MAP sensor on BMS case.
Not sure with RaceChip. Post the picture when you got a chance, maybe I can help.
12-18-2014, 07:31 PM | #18 |
Rep 85
12-20-2014, 06:33 PM | #19 |
IG @bmwF9xG80
3813
Rep 7,593
Yes I did here's my thoughts.
My factory settings came in C for my engine First day Thursday evening at stock Settings immediately felt an improvement in Sport Mode, switch to Sport+ and its even more noticeable., Comfort feels live as usual, EcoPro a bit too. After driving 30-50 miles and noticed my MPG improved. 24hrs later I decided to increase to the next level D. Drove about 50 miles and def noticed improvement on all modes including MPG improvement. 19hrs later I decided to increase to next level E.. no errors no lights or anything so I thought to myself ok lets play with this setting for a few days 100 miles. Drove in highway and traffic for the next 30-40 miles. Feel the gains in every mode, MPG improvement is not as big as C/D setting. Gains are more live here for sure. I haven't had a chance to test my 0-60 yet, but that is my next step now I'll plug in the dummy and test 0-60 in each mode and at my chosen setting.
12-21-2014, 04:06 PM | #20 | |
Rep 85
Good to hear that you are liking it so far. I can't wait to install mine. I have a service appointment tomorrow. Removed the aFe Scorcher setup yesterday. If it wasn't for the fear of breaking the clips on the sensors, it would literally be less than a 10 minute install/de-install. Hope to install the RC tomorrow evening if it isn't raining too hard. My stock setting is B (for S2) and 1 (for S1). Thanks for the feedback! |
12-21-2014, 07:40 PM | #21 | |
IG @bmwF9xG80
3813
Rep 7,593
Definitely keep the stock settings for at least 50 miles so you can get a feeling also in all different modes start off from EcoPro, then Comfort, then Sport. Good Luck with your install @r33 and @opasha helped me a lot
12-21-2014, 07:47 PM | #22 |
Rep 18,712
@ROBNYC,
