2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications F10 N55 Avg IGN
      07-03-2016, 03:46 AM   #1
GTATX
GTATX's Avatar
Drives: 2020 M8 Comp First Edition
I just wanna clarify that is Avg ign range of 0.2-0.5 is ok with running 7.75 gals of e85 n rest 93.
Mods:
Run map5
Jb4 + E85 harness
BMS intake
Sprint Booster
59k on the car and been like this about a year no codes or any issues just general knowledge question. Thx
GT
GT
2020 BMW M8 Comp First Edition
2019 Panamera Turbo
2021 BMW X6M Comp
2019 BMW M5
2018 Maserati Ghibli SQ4 GranSport
      07-04-2016, 12:53 PM   #2
MissionPerformance
MissionPerformance's Avatar
Drives: '17 F31 340xi US Spec
That is normal ignition for idle condition and you should not worry about it. What is your ignition at WOT?
      07-04-2016, 03:31 PM   #3
GTATX
GTATX's Avatar
That was right after wot I could take snap shot again at wot but it stays under 1 normally .2-.5 range
GT
2019 Panamera Turbo
2021 BMW X6M Comp
2019 BMW M5
      07-05-2016, 04:08 PM   #4
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Drives: G80 M3, X4M, G07 X7m50
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
Under 3 for E85 usage is good and you're under that so even better.
Did you test your ethanol content before pouring ?
Here's a logging parameters and their meaning
http://www.n54tech.com/forums/showthread.php?t=21269
Avg Ign: Average Ignition Retard. A JB4 calculated value with a range of 0 - 6 that represents the average amount of timing below the maximum possible curve over a short term window. Lower values indicate a higher overall ignition advance while higher values indicate a lower overall ignition curve. This calculation is used by the JB4 for evaluating octane content by both map 5 (auto learning) and map 3 (methanol injection). Values below about 1.5 result in full Map 3 or Map 5 scheduled boost levels.
Values between about 1.5 and 6.0 result in lower and lower boost targets as an added safety feature for these two maps. As a general rule when using meth, race gas, or heavy E85 mixtures look for values below 2.0. When using pump gas expect values of 5 or higher.
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      07-05-2016, 08:44 PM   #5
GTATX
GTATX's Avatar
No I don't know how to check the ethanol content.
GT
2019 Panamera Turbo
2021 BMW X6M Comp
2019 BMW M5
      07-06-2016, 09:36 AM   #6
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
http://www.ebay.com/itm/251447717425...&sojTags=bu=bu
Friend of mine tested 1 station he use to go to and it was only E70 content, you cannot waste your time with less than E80 content.
IG: @bmwF9XG80
      07-08-2016, 12:27 AM   #7
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Also whats your FP_H under WOT?
If 11 or under you have too much e85 that your HPFP can handle
IG: @bmwF9XG80
      07-08-2016, 04:03 AM   #8
GTATX
GTATX's Avatar
If 11 or under you have too much e85 that your pump can handle
I'll check it out thx
GT
2019 Panamera Turbo
2021 BMW X6M Comp
2019 BMW M5
      07-08-2016, 12:18 PM   #9
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
You can also get some more direct views on the n54tech.com forums from more JB4 experts
IG: @bmwF9XG80
      07-08-2016, 04:51 PM   #10
GTATX
GTATX's Avatar
FPH stayed at 16-17 at wot and ign .3 psi 19
100F outside lol
GT
2019 Panamera Turbo
2021 BMW X6M Comp
2019 BMW M5
FSociety3812.50
      07-11-2016, 08:00 AM   #11
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
100F outside lol
Thats really good lol, only map5 ?
have you tried on map1 or 2 too ?
Do you have EWG wires ? or just the FF/E85 wires connected
I only had 4 gallons of Pure E85 + 12 gallons of 93 on map1 my avg_ign was .5 and map2 .9-1.2 range which is still awesome. (20-21 psi) since my runs 13 psi stock
IG: @bmwF9XG80
      07-11-2016, 03:29 PM   #12
GTATX
GTATX's Avatar
100F outside lol
I don't have EWG just n85 wires and 7.75 gals of e85. I never tried map 1 and 2 as boost would be limited to 14 psi max I think. I tried map 7 no issues and also map 6 with higher boost levels and still no issue. I have set my boost safety to 23psi and run map5 only as it gives me boost at the same levels of map 7 or higher. I just feel safer on map5.
GT
2019 Panamera Turbo
2021 BMW X6M Comp
2019 BMW M5
      07-13-2016, 10:17 PM   #13
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Pretty crazy lol, have you taken it to the 1/4 mile or dyno yet?
Would be awesome to see how it does on your different maps versus delta (map4)
PM me your Map6 configs if you dont mind
IG: @bmwF9XG80
      08-25-2016, 09:57 AM   #14
GTATX
GTATX's Avatar
Pics
As requested but I use map 5 mostly
GT
2019 Panamera Turbo
2021 BMW X6M Comp
2019 BMW M5
FSociety3812.50
      08-25-2016, 01:04 PM   #15
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Thanks GTATX who configured map6 for you ? have you posted your logs / settings on n54tech or sent to Terry curious ?
FF/Wasteadaption is so high never seen that before
IG: @bmwF9XG80
      08-25-2016, 04:51 PM   #16
GTATX
GTATX's Avatar
I only changed map 6 boost numbers myself. Rest are default or adapted due to map 5 I assume. Never touched other values.
GT
2019 Panamera Turbo
2021 BMW X6M Comp
2019 BMW M5
      08-25-2016, 04:57 PM   #17
GTATX
GTATX's Avatar
I know it maxs out at 150 but is it a worrying issue. Never had any issue with the car.
GT
2019 Panamera Turbo
2021 BMW X6M Comp
2019 BMW M5
      08-28-2016, 01:11 PM   #18
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Got any logs?
Have you posted on N54tech ?
IG: @bmwF9XG80
      11-22-2016, 12:06 PM   #19
GTATX
GTATX's Avatar
Got any logs?
Haven't done logs been running fine but will post logs when get a chance.
GT
2019 Panamera Turbo
2021 BMW X6M Comp
2019 BMW M5
      11-22-2016, 06:28 PM   #20
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Your FF/Wastegate Adaptation is really high, send a log to Terry@burgertuning.com or post it on the forum i remember seeing someone lately and 150 is bad. Being so close to 150 I would try putting it back to 60 and see if it re-learns.
IG: @bmwF9XG80
