2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications F10 N55 Open ended J Pipes mod
      03-23-2016, 11:19 AM   #23
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
Originally Posted by Hasser
stupid question but does the support bracket affect the drone / noise at all?
Nothing to do with drone. There's nothing worse when driving behind someone with a custom exhaust, they hit a bump and the exhaust tips wobble around. The bracket is OEM it just had to be cut and moved up a little to accommodate the j pipes.
IG: @bmwdoubles
      03-23-2016, 03:11 PM   #24
Noncom23
Noncom23's Avatar
Drives: 2015 535i
2015 BMW 535i  [0.00]
Great mod. Any HP/Tq gains?
Mike F
      03-23-2016, 03:54 PM   #25
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
Cheers, mine is currently removed.
2014 M5
1990 E30 318i Touring
1999 E38 728i -sold
M235i - sold
Activehybrid 5 - sold
      03-23-2016, 04:30 PM   #26
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
That has not been determined yet. We're going to the dyno next week and we'll see if we can identify any gains. Maybe be difficult since here was never a baseline. I did the mod because I hated how quite it was. If I was to guess I would say stock setup no gains, tuned to take advantage of the faster exhaust gases, possibly.
IG: @bmwdoubles
      11-10-2016, 10:57 AM   #27
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
I just put a set of OEM M5 mufflers on and I have severe drone from 1500-2000 rpm. Does that sound right to you for OEM M5 mufflers?
Also, where did you get the J pipe done? What size piping did you use? I want to get this done ASAP.
      11-10-2016, 09:08 PM   #28
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Low rpm has drone sound and then cleans up at about 22-2400rpm. The trick is to get an audio analyzer, jot down the frequency that is driving you crazy then use the helm holtz equation to mathematically come up with the length of the pipe that will cancel your drone sound. I used a 2" pipe off my 3". I ended up wanting more sound so I chopped one of the end caps of the j pipe and now it's perfect, to me.
IG: @bmwdoubles
      11-10-2016, 10:04 PM   #29
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
What shop did the work for you for such a good price? I'm also located in LA. Work in Brentwood.
      11-10-2016, 10:33 PM   #30
The_M6
The_M6's Avatar
Drives: 2013 M6
Car sound great and props for the unconventional method.
Project Gamma Intakes / Project Gamma Catless Downpipes / Muffler Delete / DME Stage II Tune / H&R Springs
      11-10-2016, 11:11 PM   #31
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
Also what length of pipe did you use?
      11-11-2016, 01:09 AM   #32
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Mikes performance muffler shop
221 W Florence Ave, Los Angeles, CA 90003
Juan is the owner and you should be able to get it done for under 200 maybe less. Bring cash.
My annoying 110hz was this equation ( 1100 / 110hz ) / 4 ) x 12 = 30 inches
This will vary for you depending on what frequency annoys you
IG: @bmwdoubles
      11-11-2016, 09:47 AM   #33
paul223
paul223's Avatar
Drives: F10
This maybe a great sound mod but in long run you will have exhaust smoke stuck to car's body panels!
      11-11-2016, 11:04 AM   #34
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
Jose is the owner and you should be able to get it done for under 200 maybe less. Bring cash.
My drone is anywhere from 1400-1800 at worst depending on how hard I've driven the car. If my math is correct, I'm looking at a 42-46 inch pipe....don't know how I'm going to fit that in there.
      11-11-2016, 11:54 AM   #35
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
Sent them a message via yelp and Emilio called me right away. Sounded very comfortable doing the job unlike my local exhaust shop. Looks like I'm headed down there tomorrow! Quoted me a good price too.
      11-11-2016, 05:01 PM   #36
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
Well, decided to go in today and wow, I'm dissapointed I ever wasted money at any other exhaust shop. These guys knew what they were doing, no doubt about that.
The prior owner of my mufflers had welded on a 3 inch pipe due to him having a 550. Then the last muffler shop I went to had put on 3 different pieces just to transfer the 3 inch to my 2.25!
Mike's Performance exhaust redid my piping with 1 smooth piece, re-welded the mufflers, and I got an x-pipe put on as well. The drone did not go away, so I then had them put on a 38 inch j pipe to target my peak 1800 rpm drone....and it worked!!!
Exhaust is a little bassy/drony from 1000-1500, clears up completely till 2200, then the exhaust comes to life. I'm extremely pleased with the results.
      11-11-2016, 06:07 PM   #37
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Awesome, I found my exhaust sweet spot too. They rock indeed. Glad everything worked out. What I as your final out the door cost?
I have a bass sound in that area too. Oh yeah pics!
IG: @bmwdoubles
      11-11-2016, 06:09 PM   #38
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Put up pics
IG: @bmwdoubles
      11-11-2016, 09:31 PM   #39
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
IG: @bmwdoubles
      11-12-2016, 12:11 AM   #40
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
$400. The M5 mufflers I purchased were installed on a 550 so they ended up hacking off all the BS mismatched piping all the way back to the cats. Had an X Pipe installed in place of the cats, solid piping to the mufflers, and two 38 inch j pipes installed. I thought it might have been a little steep but I was happy with the work.
      11-12-2016, 12:13 AM   #41
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
I unfortunately forgot to take more pics other than these. I'll snap some more shots later. I still dislike that 1000-1500 rpm drone. I'm wondering if I remove the permanently opened valves if it'll help.
      11-12-2016, 12:15 AM   #42
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
How severe is your low end drone? I have a 8AT so it automatically wants to shift to the highest gear possible...putting me in that 1300 rpm drone spot. Really don't want to have to drive in sport all the time. Wondering if these M5 mufflers just naturally have more bass. I would prefer more rasp.
      11-12-2016, 11:32 AM   #43
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
The word rasp is subjective. I think I know what you're trying to say. I too wanted a less bassy tone. It was an evolution of my exhaust really and the final product for me was the following:
Magnaflo straight through mufflers
2 " j pipes with one closed and the other open
And a mild burble exhaust tune with my DP. Without the DP the burble tune was more aggressive, but negated by the DP.
Food for thought. Juan wanted to make me end caps for the j pipes that I could bolt on and off. Didn't go that route, but that's still on option for me. Another thought would be get the electronic exhaust valve. Juan sells them.
IG: @bmwdoubles
      11-12-2016, 11:37 AM   #44
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
More photos
