2010 2011 BMW 5 Series Forum F10 20" wheel, larger profile tire help please! |
05-16-2017, 11:18 AM | #1 |
Rep 1,891
Hey all -
I'm picking up a set of VFF 102s and need to get tires. Rims are: 20x9 ET30 20x10.5 ET40 I don't have offsets as I don't believe Vorsteiners provides them. That being said, I was looking to go with a beefier tire setup as I don't plan on lowering the car and don't want to risk any rim damage. I was thinking of going with Sumitomo HTZ III in 245/40/20 and 275/35/20. Question is, will I run into any issues on a stock M Sport suspension on a 535? Is this increase in OD going to seriously effect my drivability and acceleration? The overall setup will be lighter than my stock 351s, so if anything it should be beneficial, right? Does anyone have photos of a stock height F10 with those profile tires? Thanks for your help! Last edited by AMT92; 05-17-2017 at 08:51 AM.. |
05-16-2017, 11:54 AM | #2 | |
Rep 78
Drives: 2013 BMW 535i M Sport
Did we post the same thing at the same time?!
But seriously, help us forum members!! Quote:
AMT92393.00 |
05-16-2017, 12:46 PM | #4 |
Rep 878
Asked and answered (those are 7-series tire fitments and will be fine):
http://f10.5post.com/forums/showthre...&highlight=303
-WJV
AMT92393.00 |
05-16-2017, 01:48 PM | #5 |
Rep 14,521
245/35r20's in the front
275/30r20's in the rear to keep the OEM rolling diameter at 26.5" that 245 you listed with a 40 series aspect ratio is going to be a bit taller tire but the rear tire you listed is fine. with a 285/25r20's very limited in tire selection but would carry a 25.6" overall diameter. with a 285/30r20's you have more of a selection to choose from however you have to keep in mind you're gonna have a taller tire since you're using 30% aspect for sidewall with a 285 which comes out to 26.8" which still comes out to almost the same diameter as the 275/30r20's now that i pulled the specs on it
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg Last edited by lsturbointeg; 05-16-2017 at 02:00 PM.. |
05-16-2017, 02:57 PM | #6 | |
Rep 1,891
245/40/20 and 285/35/20 would be 27.7" and 27.8" which are also .5% different from each other. It seems like my car would be raised about an inch all around. I think a 285 rear would also be beneficial as I can't keep traction down in a straight line from a dig...all that JB4 boost I have a front Hamann Lip and side skirt extensions. I'm hoping it won't look too 4x4ish with that tire setup. |
05-16-2017, 03:14 PM | #7 |
Rep 14,521
Speaking of side skirt extensions I forgot if you posted them or not without looking back?
05-16-2017, 03:29 PM | #8 |
Rep 1,891
05-16-2017, 04:31 PM | #9 |
Rep 1,891
Well, I ended up going with 245/35/20 & 285/30/20 Sumitomos. Decided against raising my car a whole inch.
05-16-2017, 06:39 PM | #10 |
Rep 14,521
05-16-2017, 06:55 PM | #11 |
Rep 1,891
Just in case you forgot!
05-16-2017, 08:29 PM | #12 |
Rep 14,521
That $hits clean! I almost wanna say ef it and order the same ones and wrap in carbon fiber?
05-16-2017, 08:30 PM | #13 |
Rep 1,891
05-16-2017, 08:32 PM | #14 |
Rep 14,521
Yup! $458 for the 3d replicas
05-17-2017, 10:43 AM | #15 |
Rep 1,156
I'm running the vff102's with 295/30/20 in back and 265/35/20 (michelin PSS - which tend to run a bit wider) in the front and i'm lowered on ACS springs (1")
and I haven't run into any issues with rubbing. I think you should be fine, but why are you going with a larger profiler tire, on a larger wheel, the overall size of your wheels will increase, which will make your car look like a 4x4. I'd suggest if you're going to 20" wheels then go to a lower profile tire, to maintain the same overall height of the wheel/tire email from vorsteiner with the offsets " The offset for your F10 5-series 102’s is a ET30 in the front and a ET40 in the rear. Please let us know if you have any additional questions." |
05-17-2017, 10:45 AM | #16 | |
Rep 1,891
05-17-2017, 11:25 AM | #17 |
Rep 1,156
05-17-2017, 11:32 AM | #18 | |
Rep 1,891
Probably not, but if I were to it would be with ACS or H&R OE springs which are both about an inch drop. |
05-17-2017, 12:43 PM | #19 |
Rep 1,891
05-17-2017, 06:17 PM | #20 |
Rep 1,156
