04-11-2012, 05:46 PM | #1 |
Rep 105
Here's links to E-Sys on usenet and Rapidshare. I can't guarantee how long the link on Rapidshare will last, so get it while you can.
The program works and I've been successful in coding auto fold mirrors, trunk close from inside button and key fob, and auto close of windows and sunroof with key fob. You can also unlock DVD in motion and turn off many of the notifications (i.e seat belt chime etc.) You'll need to build an interface cable (OBD to ethernet), or buy one on eBay when they become available. Overall better than paying someone to code your vehicle. Read the .nfo for more information. PM me if you need any help getting a cable built. I also have some "how-to program" using E-sys pdf's if anyone needs them. Rapidshare: The Rapidshare links have been removed thanks to our fellow enthusiasts in the BMW community. Oh well. Usenet: http://nzbmatrix.com/nzb-details.php?id=1242599&hit=1 Sean Last edited by ImSW1; 04-22-2012 at 03:38 PM.. Reason: Updated thread. |
04-12-2012, 09:22 AM | #2 |
Rep 519
WTF U TALKIN BOUT
_____________________________________________
2016 M6 GC under construction,2013 F10 M5 Akrapovic(sold) 2012 F10 AW 550i MSPORT,Vossen CV3s,ACS Springs,Meisterschaft GTC,.Totalled! E60 M5 Dinan stg3,hiflow throttle bodies,coldair,evosport rear diff,Eisenmann Race sold E39 M5 UUC short shift,UUC Corsa and More Sold |
04-12-2012, 11:07 AM | #3 |
Rep 105
E-Sys
Good question. Should have started out with that...I guess.
E-Sys is the program that is used to reprogram the modules in the F-series vehicles. In other words, if you want to program your mirrors to fold when you hold your remote button, or close the trunk with the key fob you do it using e-sys and a specialized cable (ethernet to OBDII). This is the first sighting of the program and activation tools to get communication with the car. Sean |
04-22-2012, 08:52 AM | #5 |
Rep 131
Drives: 2011 BMW f10 550i M
Just PM you.
04-22-2012, 02:04 PM | #6 |
Rep 105
Easy Cable Build Instructions
I wanted to post some easier to follow cable instructions for those that don't read schematics. My hope is more people will attempt to code their own cars. The only cable I've seen out on ebay is $50.00 and that's ridiculous. It will cost you about $10 to $15 if you have basic soldering skills and order the parts. You could also just buy a standard ethernet patch cable and cut one end off and solder the open ends to the OBD2 connector.
Sean |
04-22-2012, 04:04 PM | #8 |
Rep 105
It's actually pretty easy to use once you've used it once or twice. The instructions are out there.
You can find them by searching for "E-Ssys - Getting_Started-Coding.pdf" without quotes in google. This search will take you to a russian website. Use google chrome to translate then signup and download the files. I can't post the url to the site (Bimmerpost won't allow it) that the "how-to's" came from but credit to Modular93fox and the other users that created the documents so others could learn. Sean |
04-22-2012, 07:57 PM | #10 |
Rep 45
i found this info after this post. I hope it helps
http://bmwcoders.com/forum/bmw-isis-...6/bmw-e-sys-6/ |
04-24-2012, 01:20 PM | #11 | |
Rep 5
04-25-2012, 08:49 AM | #12 |
Rep 60
Thanks everyone! I just ordered my car this past weekend - wont be in for 6 weeks but figured I'd start prepping... Screwed up and bought the ODB cable for the older cars so I'm down $100 so far...
Since this is all new to me - I'm really lousy with a Solder is there anywhere to buy the ethernet to odb cable yet? Also I'm searching for "E-Ssys - Geting_Started-Coding.pdf" on google and nothings coming up... Any help would be appreciated! |
04-25-2012, 09:10 AM | #13 | |
Rep 40,302
Drives: 2018 Alpina B6 650ix GC
BMW F-series ENET cable (required for BMW F01, F02, F10 remote coding services) http://www.codecard.lt/electronics/t.../prod_651.html Attached is the E-Sys - Getting Started: Coding.pdf. The document password (PW) is at the end of the file name.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 04-25-2012 at 09:19 AM.. |
04-25-2012, 01:06 PM | #15 |
Rep 60
Having spent all morning reading and getting the appropriate tools installed - How do you know what code to change for the DVD in Motion or the automatic mirrors? Is there a master list somewhere or do you have to get lucky?? I looked on BMWcoders.com as well... maybe I'm just dense?
Thanks again - Not easy being the newbie.. |
04-25-2012, 01:12 PM | #16 | |
Rep 40,302
http://www.**************/showwiki.p...Coding+Options The masked website is the same as the document Password above.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
06-16-2012, 10:24 PM | #18 |
Rep 2
Hi, can anyone share the location to download all the psdzdata files? Apparently, it seems that the files is no longer in Rapidshare. Thanks in advance for the helps.
Cheers! |
06-16-2012, 10:32 PM | #19 | |
Rep 40,302
http://www.bimmerfest.com/forums/sho...08&postcount=1
06-21-2012, 08:45 PM | #20 | |
Rep 2
Thank you and appreciated.. It seems that my current IP address does not allow me to access to the files. I had tried another network and it is working.
09-05-2012, 04:06 AM | #22 |
Rep 40,302
ImSW1 has been out of pocket for a while. What is it you need? A Cable?
