2010 2011 BMW 5 Series Forum F10 BMW 5-Series Gran Turismo GT (F07) Forums General 5-Series GT (Gran Turismo) (F07) Forum Anyone with H&R springs on their GT?
      03-26-2011, 11:42 AM   #1
Robbo335
Sweden
11
Drives: 525iA Tour / 535i GT / M3 Conv
Hi all,
as the title says; are there any members who have H&R springs?
I'm looking for photos with OEM 20" wheels - if there any available please post them.
This is the only one I found.
Also other lowering springs are of interest - please post pics!
Cheers
R
***Update: H&R springs are now installed. Rear is set by using the adjustable ball joints supplied together with the springs - no need to electronically adjust the ride height. Now only front and rear spacers are needed...***
      03-29-2011, 01:59 PM   #2
bimmer man
Norway
75
Drives: 745le xdrive 2020, i3 2020
2020 745le  [0.00]
2012 640i  [10.00]
Originally Posted by Robbo335 View Post
Hi all,
Cheers
R
look at hartge.de I orded 30 mm dropp today from bmw strandveien auto in trondheim norway. I orded hartge 22" wheels last mont. Hope summer comming soon
      03-29-2011, 02:09 PM   #3
78mao
78mao's Avatar
Taiwan
133
2015 M3 BMW M3  [1.00]
damn 22s? a lil big for the 5 i think!
i saw the CEC car at SEMA with 22s AC's wheels and I thought they looked kinda akward!
      03-29-2011, 07:39 PM   #4
car_fan
car_fan's Avatar
382
Drives: 2020 F97 X3M
2020 BMW X3M  [0.00]
  [0.00]
Niiiice Looking F10 you got there - 3 Thumbs Up!
2011 MINI CooperS BRGII/Lounge Green/Sport/Prem/Connect/Black Xenon/Black Conical Spokes/ACS springs/ACS exhaust/Alta Shorty/Yokohama Advan Sport A/S
2012 M3 AW/FR NDH2/2MK/ZPP/ZCP/ZCW/752/6NR/OEM CF splitters/OEM CF Mirror caps (retired)
2012 X3 35i Titanium Silver/Black ZAP/ZPP/TECH/APPS/Breyton GTS (retired)
2018 X3 M40i BSM/Oyster/ZPP/ZPX/HK/S6CPA/718M(retired)
      03-30-2011, 08:36 AM   #5
Robbo335
Sweden
11
Doesn't Hamann use H&R springs?
Anyway, this GT has 22" wheels but I wanted to see one with 20".
      03-30-2011, 06:18 PM   #6
jadnashuanh
Drives: 535iGT x-drive; i3 BEV
It looks slick, but you better have good insurance for the wheels and tires. Those rubber bands won't take much of any impact. Great looks, and probably handling on smooth roads, but not real-world in most.
      04-07-2011, 10:19 PM   #7
BaltimoreGT
Drives: 550i GT/black/Sport pkg/20"
Any opinions on ride quality on the springs?
I lowered my other car on coilovers, and given they are coils I could iteratively raise back up. The shocks perform better and better, as the height rises. So, I would expect our complex suspension to be even more sensitive as you lower it 35 mm.
Any thoughts?
Any pics?????????
      04-20-2011, 04:20 AM   #8
Robbo335
Sweden
11
The ride quality seems to be more or less the same - I went from 19" RFT winter tires to H&R with 20" RFT sommer tires so there is some uncertenty here... It has a big influence if you lower the rear to much. When the setting is to low the ride was very stiff. After readjusting the ride hight it was much better.
      04-21-2011, 02:26 AM   #9
BaltimoreGT
Thanks for the reply Robbo335!
So, how low are you in the rear? I thought the drop was fixed at 30 mm.
Any rubbing under hard cornering?
Does the car feel like it can be driven harder?
What about ground clearance - any scraping on driveway etc?
      04-21-2011, 03:05 AM   #10
78mao
78mao's Avatar
Taiwan
133
thanks!!!
      04-21-2011, 01:06 PM   #11
Robbo335
Sweden
11
The H&R kit is supplied with an adjustable rod link for the rear axle- you can therefore set the ride height at wished level. If you just lower it by 20 mm there will be no real difference in ride comfort.
I chose c-c 69 mm whereas the standard c-c is 73 mm.
      04-21-2011, 07:58 PM   #12
BaltimoreGT
What about the front, and any rubbing?
Hi Robbo335, so what is the lowering of the front in the picture you posted? And do you have any rubbing in the front after the spring swap? Lastly, does the car corner harder?
Thanks for all your info!!!
      04-22-2011, 03:10 AM   #13
Robbo335
Sweden
11
Hi BaltimoreGT,
There is absolutely no rubbing! I plan to ad 10 mm spacers up front and 10 or 15 mm at the rear - there is plenty of space when using original wheels.
The front springs are to lower the GT by 35 mm (1,4") and the rear is adjustable with the H&R rod links controlling the height of the air suspension.
I have a hard time saying if it corners better or not as I simultaneously went from 19" winter to 20" summer tires.
R
      04-23-2011, 07:59 PM   #14
BaltimoreGT
Robbo335, thanks for the reply!
This is great news. I also read Bimmer_man's response in another thread.
It seems that the lowering springs are a great mod with little detriment.
Bimmer man seems to believe cornering improved significantly.
I like your car too. I am sure the summer tire package complicates your determination. That is a huge difference in grip.
Enjoy the summer in that car - looks fun.
      04-25-2011, 09:27 PM   #15
blkcofy
blkcofy's Avatar
Drives: 2010 550i GT Sport Dinan
Hi BaltimoreGT,
R
Quick question...If using H&R and lowering it 20mm to 30mm (max) and there's no rubbing, what is the benefit/purpose of the wheel spacers?
      04-25-2011, 11:21 PM   #16
BaltimoreGT
spacers
I was wondering the same thing. My guess is the spacers are being added for aggressive looks and a wider track. A wider track might add a very slight performance gain. Although, it also increases the chance to rub. Probably, the OP sees there is room without risk of rubbing and is doing this more for looks.
Those H&R do sound tempting.
      04-29-2011, 02:11 PM   #17
Robbo335
Sweden
11
Thats right!
the spacers are purely for looks - just to fill out the wheel arches! As my wheels are original BMW there is no risk for rubbing, not on the inside nor the outside.
I'll report back after they are put on the car!
cheers
R
      05-06-2011, 10:21 AM   #18
jadnashuanh
Any time that you move the wheel location out, you put more stress on the bearings because the lever arm is longer. While this may not be a major factor, it is a factor to be considered. Depending on the wheel design, it may also affect the brake cooling (probably insignificant). Depending on the spacer, tire, and wheel, it may also expose the body to more sand and stone chipping.
      02-21-2012, 06:32 PM   #19
M5 TT
Scotland
169
Drives: F90 M5
have you got a link to where you bought your springs. According to a few suppliers i have tried in the UK they only come with front springs and no rear links?
Paul
540i
GTR-R35, F90 M5, X3MC, RS3, RS7, M5, S7, S3, RS3, RS6, GTR R35, 996 Turbo, M5, RS6 V10, Cayenne Turbo S
      02-22-2012, 12:59 PM   #20
jadnashuanh
Lowering the rear (via an adjustable link) is unlikely to change the spring rate, so there is a risk of bottoming out something, since the wheel must be now closer to the body. It sounds like the self-leveling air suspension still has it's full travel, but now the space it has to travel is smaller. This is also likely to change the alignment angles (maybe for the better?) so you should watch the wear very carefully. Getting each side exactly the same would also be important.
      02-22-2012, 01:01 PM   #21
jadnashuanh
Good luck, report back after you've put maybe 5K miles or so on it on handling, tire wear, and ride characteristics.
      02-25-2012, 01:50 AM   #22
M5 TT
Scotland
169
Drives: F90 M5
Ordered and on their way.
US part number 50469
UK part number 28963-1
540i
