2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum F11 electric opening tailgate
      03-10-2011, 05:34 PM   #1
schneeky
F11 535d SE week 40 production
Drives: BMW F11 535d SE Touring
Hi All
Since new it has always irritated me that if I open the tailgate of my F11 (which has electric closing function) using the door handle (and not the key) I literally have to push it up - the friction is that great.
I assumed that this was just a "feature" of opening manually. However the other day, I saw an X6 owner open the tailgate using the handle and it glided open under it's own power. Is this how my F11 should work too? Is there a setting I have to enable or is this just an X6 only feature deliberately missing from the F11?
Sorry being lazy haven't checked the manual yet.
      03-10-2011, 08:04 PM   #2
jamier9
Drives: BMW 523i F10
I think if you are opening it manually, just manually release the lever and quickly let it go. It will glide up on its own power.
I tried to manually open my F10 boot like you when I first got the car,manually pushing up the boot and experienced the same friction....trick is to just release the lever and let the electric tailgate do its stuff.
      03-11-2011, 03:15 AM   #3
james d
DOME
Drives: G21 M340
Do you have the optional Powered Tailgate? Bit confused by Electric closing function,assumed you either have the powered option or not?
      03-11-2011, 08:59 AM   #4
jamier9
I think he is referring to the powered option.
      03-11-2011, 09:27 AM   #5
Snapper Chris
Drives: BMW 535i SE Touring F11
Once you press the tailgate release handle the mechanism will then automatically open the tailgate fully . If you try and assist the opening of the tailgate by hand the opening process will stop immediately. Presumably the mechanism senses any outside force and switches off as a safety precaution. Although you can force the tailgate up by hand as you have been doing, it requires a fair amount of force which suggests that it's not designed to be operated that way other than in an emergency.
      03-11-2011, 03:21 PM   #6
schneeky
OK Thanks - feeling dumb!! Will try tonight.
Tags
f11, tailgate
